IBMIoTConnector
Connects to IBM’s Watson IoT Platform through the MQTT protocol. Supports sending (producing) and receiving (consuming) messages.
- Connect and control IoT devices
- Manage device data for use on Watson IoT platform and other services
- Interoperability with Big Data analytics platforms
The output of this transformer will vary depending on the action performed. Message data and metadata are presented as feature attributes.
- After a Subscribe action, output features represent messages received from IBM Watson IoT Platform.
- After a Publish action, output features represent messages sent to IBM Watson IoT Platform.
The incoming feature is output through this port.
Features that cause the operation to fail are output through this port. An fme_rejection_code attribute, having the value ERROR_DURING_PROCESSING, will be added, along with a more descriptive fme_rejection_message attribute which contains more specific details as to the reason for the failure.
Note: If a feature comes in to the IBMIoTConnector already having a value for fme_rejection_code, this value will be removed.
Credential Source |
Using a web connection integrates best with FME, but in some cases, you may wish to use one of the other sources.
Account |
Available when the credential source is Web Connection. To create an IBM IoT connection, click the 'Account' drop-down box and select 'Add Web Connection...'. The connection can then be managed via Tools -> FME Options... -> Web Connections. |
Organization ID | Available when the credential source is Embedded. The organization ID to use when connecting to IBM Watson IoT Platform. This is a globally unique ID assigned when first registering for IBM Watson IoT Platform. |
API Key, Authentication Token | Available when the credential source is Embedded. The API key and Authentication token to use when connecting to IBM Watson IoT Platform. The API key has the form a-{orgId}-{apiKeySuffix} |
CA Certificate |
Root CA certificate for broker. Optional. |
Client Certificate |
Certificate for client authentication. Optional. |
Client Private Key |
Private key for client authentication. Optional. |
Action |
The type of operation to perform. Choices are:
QoS Level |
The MQTT protocol allows a Quality of Service (QoS) level to be set. The following levels are available:
The QoS guarantees are achieved by performing differing levels of client-server handshake. As a result, higher QoS levels are expected to lower throughput. |
The remaining parameters available depend on the value of the Request > Action parameter. Parameters for each Action are detailed below.
Send Options
Device type |
The type of device to publish command to. The device type is used to identify and group devices with similar characteristics. |
Device ID |
The ID of the device to publish command to. The device ID is used to uniquely identify a device within a particular device type. |
Command ID |
The ID of the command to publish to a device. The command ID can be any valid string accepted in the MQTT protocol. The device subscribing to the command can either subscribe to the command with the same string or the wildcard value `+`. |
Format string |
A string to identify the content type of the payload. Most commonly `json` but can be any string that is valid in MQTT. |
Payload |
The content of the message. This is often JSON, but can be any string, binary, integer or floating-point value. |
Send Options
Device type |
The type of device to publish an event as. The device type is used to identify and group devices with similar characteristics. |
Device ID |
The specific device to publish an event as. The device ID is used to uniquely identify a device within a particular device type. |
Event ID |
The ID of the event to publish as a device. The event ID can be any valid string accepted in the MQTT protocol. |
Format string |
Payload |
Subscription Options
App ID |
The ID of the application to monitor the status of. To subscribe to the status of all applications, set the app ID to the wildcard value `+`. |
Receive Mode |
Two message receiving options are available:
Batch Size |
In Batch mode, specifies the number of messages to read per batch. |
Device type |
The type of device to subscribe to commands to. The device type is used to identify and group devices with similar characteristics. To subscribe to commands for all device types use the wildcard value `+`. |
Device ID |
The specific device to subscribe to commands to. The device ID is used to uniquely identify a device within a particular device type. To subscribe to commands for more than a single device, use the wildcard value `+`. |
Command ID |
The ID of the command to subscribe to. The command ID can be any valid string accepted in the MQTT protocol. The device or application subscribing to the command can either subscribe to the command with the same string or the wildcard value `+`. |
Format string |
A string to identify the content type of the payload. Most commonly `json` but can be any string that is valid in MQTT. To subscribe to multiple formats, use the wildcard value `+`. |
Receive Mode |
Batch Size |
Device type |
The type of device to monitor the status of. The device type is used to identify and group devices with similar characteristics. To subscribe to the status for all device types use the wildcard value `+`. |
Device ID |
The specific device to monitor the status of. The device ID is used to uniquely identify a device within a particular device type. To subscribe to the status for more than a single device, use the wildcard value `+`. |
Receive Mode |
Batch Size |
Device type |
The type of device to subscribe to events to. The device type is used to identify and group devices with similar characteristics. To subscribe to events for all device types use the wildcard value `+`. |
Device ID |
The specific device to subscribe to events to. The device ID is used to uniquely identify a device within a particular device type. To subscribe to events for more than a single device, use the wildcard value `+`. |
Event ID |
The ID of the event to subscribe to. The event ID can be any valid string accepted in the MQTT protocol. The device or application subscribing to the event can either subscribe to the event with the same string or the wildcard value `+`. |
Format string |
Receive Mode |
Batch Size |
The following attributes can be selected for inclusion on the output features. Each output feature represents a message that was either sent or received.
_message_id |
The sequential identifier for the message. |
_payload |
The message payload. UTF-8 string if possible to decode, otherwise binary or numeric. |
_topic |
The topic the message received from or sent to. |
_qos |
The quality of service level with which the message was sent or received. |
Dialog Options - Tables
Dependencies | |
Aliases | |
History | Released FME 2019.0 |
Search for all results about the IBMIoTConnector on the FME Community.
