GeometryPartExtractor
Extracts selected geometry parts based on a Geometry XQuery.
Note: For geometry information, see FME Geometry Model.
Input Port
Features with geometries.
Features with newly extracted geometry parts.
Original feature with selected parts removed.
Note: This port always outputs a geometry, even if it is null.
Features that were not modified by the transformer.
Geometry Part Selection
Use this parameter if you want to isolate only a portion of the geometry passed in to the transformer. If no criteria are specified, the action will apply to the entire geometry at all levels.
Selection can be based on structural location, geometry name, type, appearance information, traits, trait storage types, or definition reference. The syntax used is a restricted set of XQuery, where the return clause is fixed.
The basic Geometry XQuery dialog allows you to construct simple selection queries by automatically writing the necessary query based on specified test clauses. Clicking the Switch to Advanced button opens the Advanced Editor, which allows you to type a query free-form, for more expressive queries.
Note: Once you switch to Advanced mode, you will have to clear all parameters before you can return to Basic mode.
A hierarchical geometry is represented as nodes of type geometry, with attributes containing information about traits, type, and name for each geometry.
Note: Unlike other transformers that contain the Geometry XQuery parameter, this transformer requires that you specify a Geometry XQuery. If you want to extract every single part, one method is to use an XQuery that matches the "Hierarchy Position" to "Leaf Node". Alternatively, you can use a Deaggregator in hierarchy mode, which may produce more useful output.
Dialog Options - Tables
Keywords: GeometryPartRemover
