FMEServerLogFileRetriever
Accesses the translation log for a specified FME Server-run translation. The translation log to access is identified by the job ID input parameter.
Dependencies
This transformer requires an FME Server connection.
The initiating feature is output via the Succeeded port if the translation log was successfully retrieved for the specified job ID, and will have these attributes added to it:
- _log_attr: the contents of the translation log for the specified job
The feature will be output via the Failed port if the translation log was not successfully retrieved for the specified job ID, and will have these attributes added to it:
- _job_failure_type: contains the reason for the translation log retrieval failure
- _log_attr: the contents of the translation log for the specified job, obtained before an error occurred
Connection
You can connect to an FME Server in one of the following ways:
Specify a web connection to an FME Server. Web connections can be reused in multiple workspaces, and connection parameters are hidden in the workspace. For more information, see Using Web Connections.
When checked, you must specify the connection parameters to the FME Server manually. The connection parameters are visible in the workspace. To connect, specify:
Enter a URL to access FME Server. You may need to contact your System Administrator for the URL.
Provide your FME Server credentials.
Note: You can click the Status hyperlink to ensure that the FME Server connection has been successfully established.
This parameter is the job ID of the translation log that is to be requested.
This parameter is the output feature attribute that the translation log is to be written to. By default, the value is _log_attr.
Dialog Options - Tables
