EthereumConnector
Interacts with the Ethereum blockchain network. The functions include reading transaction, address, or block information, sending transactions, or interaction with deployed contracts.
- Reading transaction, address, or block information
- Sending transactions
- Interacting with deployed contracts
The Ethereum blockchain is an immutable and distributed ledger. Once data is stored on the blockchain it cannot be changed or deleted. Information is added to the network by sending a transaction. Ethereum also allows code execution called contracts, which together can create decentralized applications (Dapps). The EthereumConnector allows:
- Reading stored information
- Storing data
- Interacting with Dapps
There are 2 methods of connecting to the Ethereum network through the connector.
- An rpc url to an ethereum node. https://infura.io is a popular node service, or you can use a local or another hosted node.
- An API Key from https://etherscan.io.
A private key is required to send a transaction. The key is generated when you create an ethereum wallet.
- There are multiple ethereum networks. The public mainnet requires real ether for the transaction fee to send transactions. For testing purposes, we recommend using a testnet as transactions are free and ether has no monetary value. However, testnets should only be for testing purposes and should not be used for production.
Output will depend on the method chosen.
The incoming feature is output through this port.
Features that cause the operation to fail are output through this port. An fme_rejection_code attribute, having the value ERROR_DURING_PROCESSING, will be added, along with a more descriptive fme_rejection_message attribute which contains more specific details as to the reason for the failure.
Note: If a feature comes in to the EthereumConnector already having a value for fme_rejection_code, this value will be removed.
Credential Source |
The EthereumConnector has 2 methods for accessing the Ethereum network.
Node URL | The URL to use when Node is chosen as the Credential Source. |
Etherscan API Key | The API Key to use when Etherscan is chosen as the Credential Source. |
Network | The network for Etherscan to use. “Mainnet” is the main ethereum chain. We recommend using the Ropsten testnet for development. You enter any testnet supported by etherscan, i.e. “Kovan”, but your results may vary. |
Action |
The type of operation to perform. Choices are:
The remaining parameters available depend on the value of the Request > Action parameter. Parameters for each Action are detailed below.
Retrieves metadata information for an address.
Get Address Options
Address | The ethereum address. |
Output Attributes
_balance | The ether balance of the address. |
_transaction_count | The number of transactions going out from an address. |
Retrieves transactions from the address as features.
If using the Node credential source, only the transactions in the last 100 blocks are returned. This is about 20 minutes back in time on the mainnet. It is recommended to use Etherscan to retrieve all outgoing transactions on an address as the last 10000 transactions can be retrieved.
Get Address Options
Encoding | The encoding used for the _input output attribute value. |
Output Attributes
_block_hash | The block hash of the transaction. |
_block_number | The block number of the transaction. |
_from_address | Address the transaction was from. |
_gas | The gas used to send the transaction. |
_gas_price | The gas price when the transaction was sent. |
_hash | The hash of the transaction. |
_input | The data on the transaction. |
_to_address | Address the transaction is to. |
_transaction_index | The integer transaction index in the block. |
_value | Ether value of the transaction. |
Retrieves metadata information on a block.
Get Block Options
Block Number | The block number or block hash. |
Output Attributes
_difficulty | The difficulty of the block. |
_extra_data | Extra data added to the block when it was created. |
_gas_limit | The gas limit set on the block. |
_gas_used | The gas used mining the block. |
_hash | The block hash. |
_latest_block_number | The most recent block number. |
_miner | The address that mined the block. |
_number | The block number. |
_parent_hash | Hash of the block’s parent. |
_size | The total size in bytes. |
_timestamp | The time the block was created. |
_total_difficulty | The total difficulty of mining the block. |
Retrieves transactions on the block as features.
Get Block Options
Output Attributes
Retrieves a single transaction.
Get Transaction Options
Transaction | The hash of the transaction. |
Output Attributes
Read a method on a deployed contract.
Contract Options
Contract Address | The address where the contract lives. |
ABI | A file that contains the application binary interface. |
Contract Function | The name of the function to call. |
Output Attributes
_value | The value of the called function. When using the node connection type, the output value will be formatted to the function return type. Etherscan will return the unformatted byte value. |
Send a transaction to the network.
Send Transaction Options
Private Key | The private key used to sign the transaction. |
From | The address where the transaction is sent from. |
To | The address to send the transaction to. |
Value (Eth) | The value of the transaction in Eth. |
Data | Added data to the transaction. |
Encoding | The encoding used for the data parameter. |
Gas Limit | The max amount of gas to use. |
Gas Price (Gwei) | The price set for gas. If the transaction fails, try increasing the gas price. |
Wait for receipt | If Yes, wait until the transaction is broadcasted on the network with a hash before returning the feature. If No, immediately return the feature. |
Output Attributes
_gas_used | The gas used to send the transaction. |
Execute a write method on a deployed contract.
Write Contract Options
From Address | The address where the transaction is sent from. |
Contract Address | The address where to execute the function. |
Contract Function | The function to execute. |
Function Params | The parameters of the function in comma-separated form arg1,arg2. |
Output Attributes
Dialog Options - Tables
Dependencies | Ethereum connection |
Aliases | |
History | Released FME 2019.1 |
Search for all results about the EthereumConnector on the FME Community.
