CKANConnector
Connects to a CKAN open data portal using the CKAN Action REST API. Supports reading and writing CKAN Dataset and Resource metadata, downloading of file-based Resources, and uploading files to the CKAN FileStore. Does not support row-based operations against CKAN DataStore Resources.
- Browsing and downloading public datasets hosted on a CKAN portal
- Creating or updating metadata and file-based Resources
The output of this transformer will vary depending on the Request Action performed. Dataset and Resource metadata are presented as feature attributes.
The incoming feature is output through this port.
Features that cause the operation to fail are output through this port. Rejected features will have attributes fme_rejection_code and fme_rejection_message detailing the cause of rejection. Error responses from the CKAN server will have a fme_rejection_code value of ERROR_RESPONSE, with fme_rejection_message being the error messages returned by the server.
CKAN Connection |
Specifies the CKAN Connection to use. CKAN Connections define the CKAN Server URL and an optional API Token for authenticated access. |
Action |
The type of operation to perform. Choices are:
The remaining parameters available depend on the value of the Request > Action parameter. Parameters for each Action are detailed below.
Create Dataset
Name |
Name of the dataset. Must be unique on the CKAN portal, and be alphanumeric with no spaces. |
Title |
Title of the Dataset. |
Private |
Author |
Name of the author. |
Author Email |
Email address of the author. |
Maintainer |
Name of the maintainer. |
Maintainer Email |
Email address of the maintainer. |
License |
Dataset license. Select from one of the options available on the CKAN portal. |
Notes |
Notes, comments, or description for the Dataset. |
Source |
The source URL for the Dataset. |
Version |
Version information for the Dataset. |
Tags |
Tags for the Dataset. Select from the options available on the CKAN portal. The server may create tags if they don’t already exist. |
Groups |
Assign the Dataset to these groups. Select from the options available on the CKAN portal. |
Organization |
Organization that controls the Dataset. Select from the options available on the CKAN portal. |
Output Attributes
JSON Response Attribute |
The JSON object representing the Dataset is stored in this attribute. Optional. |
Data Source
Data Source |
File to Upload |
Path to the file to upload. |
Attribute to Upload as File |
Name of attribute to upload. |
Upload with File Name |
When uploading an attribute, set this as the filename for when the Resource is downloaded. |
URL |
URL to set on the Resource. |
Resource Metadata
All of the following parameters are optional, aside from the Dataset.
Dataset | ID of the parent Dataset for this Resource. |
Name | Name of the Resource. If not specified, the value is set to the filename or URL basename. |
Description | Description of the Resource. |
Format | File format of the Resource. |
MIME Type | The MIME type of the uploaded file or Resource URL. If not specified, the value is inferred from the filename or URL. |
Output Attributes
The JSON object representing the Resource is stored in this attribute. Optional. |
Delete Dataset
Dataset |
The ID of the Dataset to delete. |
Purge |
If Yes, the Dataset is permanently deleted and its metadata is no longer retrievable. If No, the Dataset is marked as deleted and no longer appears in search results. This is how Delete works in the CKAN web interface. Default: No |
Delete Resource
Dataset |
The ID of the Dataset that contains the Resource to delete. |
Resource |
The ID of the Resource to delete. |
Content Source
Dataset |
The ID of the Dataset that contains the Resource to download. |
Resource |
The ID of the Resource to download. |
Destination
Download As |
Download to Attribute | Download the Resource’s URL to this attribute. |
Download to Folder | Download the Resource’s URL to this folder. The filename is determined at the time of download. |
If File Exists |
Output Attributes
Attributes to Add | The _download_path attribute, if selected, contains the absolute path to the downloaded Resource file. |
Output Attributes
Attributes to Add | Sets the specified metadata field as attributes on the output feature. |
List Resources
Dataset | ID of the Dataset to list Resources from. |
Output Attributes
Update Dataset
When a field is left empty, the field’s existing value is left unmodified. To clear a field, set it to null.
Dataset ID |
The ID of the Dataset to update. |
Name |
Title |
Private |
Author |
Author Email |
Maintainer |
Maintainer Email |
License |
Notes |
Source |
Tags |
Groups |
Organization |
Output Attributes
Data Source
Data Source |
File to Upload |
URL |
Resource Metadata
Resource | ID of the Resource to update. |
Output Attributes
Dialog Options - Tables
Dependencies | |
Aliases | |
History |
Search for all results about the CKANConnector on the FME Community.
