AmazonAthenaConnector
Accesses Amazon’s Athena service to run queries on S3 datasets.
The AmazonAthenaConnector uses your Amazon AWS account credentials to access the Athena service, either via a previously defined FME web connection, or by setting up a new FME web connection in the transformer.
Costs
AWS charges for the following:
- The amount of data scanned. All data is scanned for every query, unless the underlying data supports columnar storage.
- The storage of the source data in S3.
- The storage of the results of each query in S3, which is not cleaned up by FME.
More information on pricing: https://aws.amazon.com/athena/pricing/
The Amazon Athena reader will not typically be an efficient way to retrieve entire datasets from S3 as it is intended for retrieving subsets of datasets.
The output port will contain attributes set in the Exposed Attributes parameter, which correspond to the columns from the ran query.
The incoming feature is output through this port.
Features that cause the operation to fail are output through this port. An fme_rejection_code attribute, having the value ERROR_DURING_PROCESSING, will be added, along with a more descriptive fme_rejection_message attribute which contains more specific details as to the reason for the failure.
Note: If a feature comes in to the AmazonAthenaConnector already having a value for fme_rejection_code, this value will be removed.
| Credential Source |
Credentials can be used from different sources. Using a web connection integrates best with FME, but in some cases, you may wish to use one of the other sources.
| Account |
Available when the credential source is Web Connection. To create an Amazon Web Services connection, click the 'Account' drop-down box and select 'Add Web Connection...'. The connection can then be managed via Tools -> FME Options... -> Web Connections. |
| Region | The AWS Region in which the S3 dataset resides. Overrides the region set in the web connection if specified. |
AWS CA Bundle |
The AWS CA Bundle specifies the path to a certificate bundle to use for certificate validation. If set, this has precedence over the value of the AWS_CA_BUNDLE environment variable. |
| Embedded Credentials | Available when the credential source is Embedded. An access id and secret key can be specified directly in the transformer instead of in a web connection. |
| Use Named Query | If Yes, use a named query, otherwise specify a query. |
| Named Query | A named query to run. |
| Query | The SQL query to run. |
| Query Timeout | Seconds until a running query is cancelled. The default and maximum is 30 minutes (1800 seconds). |
The bucket and path to save the results of the query. Athena generates a metadata file and a CSV file of the results.
This should not be the same location that the Athena table source data lives or the results of subsequent queries will be contaminated by the staging files.
Note: This output is not deleted when the query completes. You should either use a location with default Object Expiration, or manually delete the output.
If checked, the query will be saved for use later.
| Database | The database the saved query. |
| Title | The title of the saved query. |
| Description | The descriptive text of the saved query. |
If checked, save the results to a table.
| Database | The database to save the table. |
| Table Name | The name of the table. |
| Description | The description of the table. |
| Output Bucket | The bucket to store the table data. |
| Output Path | The path to store the table data. This location must be empty. |
| Format | The format to store the table data. Parquet and ORC are recommended. |
The list of attributes to output. These should be the column names of the query.
Dialog Options - Tables
| Dependencies | Amazon Web Services account |
| History | Released FME 2019.2 |
Search for all results about the AmazonAthenaConnector on the FME Community.
