Logging in to the Web User Interface
If you are logging in to the Web User Interface for the first time as an administrator following installation, specify Username admin and Password admin. You will be prompted to update the admin password upon initial use, based on the default Password Policy configuration.
For all other logins, enter your Username and Password and click Login. Alternatively, if single sign-on is enabled in conjunction with Directory Servers (Windows only), select Use Windows Credentials.
The FME Server installer creates a set of user accounts and passwords by default. For more information, see Default User Accounts and Passwords.
If Reset Password is enabled, you can click Forgot your password? to reset your password.
If Password Expiration is enabled and your password is expired, you are directed to change your password immediately upon login.
See Also
