WebSocket Message Received
The WebSocket trigger receives messages over TCP from a WebSocket-supported client, which can include the WebSocketSender transformer in an FME workspace, and the following Java or HTML5 web browsers:
  • Internet Explorer 10+
  • Firefox 11+
  • Chrome 16+
  • Safari 6+
  • Opera 12.10+
The WebSocket trigger has two output ports. The success port (✔) can send a message if the trigger receives it successfully. The failure port (x) can send a message if the trigger fails to communicate with the client.
WebSocket Communication Channels
The WebSocket Server is located on the FME Server Core. By default, FME Server uses the following channels for WebSocket communication:
  • Port: 7078
  • URI: ws://<hostname>:7078/websocket
To configure the WebSocket server for SSL communication, see Configuring for HTTPS.
Note: See also Working with Parameters in Automations Workflows.
Tip: To test that your parameters work as expected, click Validate.
  • Target URL: This field is pre-populated with the URL of the FME Server WebSocket Server (included with your FME Server installation). Alternatively, you can connect to a different WebSocket server.
  • Stream ID: Specify the Stream ID for the trigger. The Stream ID allows the WebSocket server to identify messages and connect them to the trigger.
Output Keys
See Also
Key Description
time Event time
source Event type
error.type (Failure port only) Error type
error.message (Failure port only) Error message
message (Success port only) Message content
Messaging Protocol
See Also
