FME Server Topic Notified
The FME Server Topic Notified trigger sends messages generated from FME Server Notification Service Topics.
The FME Server Topic Notified trigger has two output ports. The success port (✔) can send a message if the trigger fails. The failure port (x) can send a message if the trigger succeeds.
Note: Use the Topic trigger only to initiate a workflow, or a portion of a workflow. It is otherwise not necessary to explicitly define topics for a workflow to run.
Note: See also Working with Parameters in Automations Workflows.
  • Topics: Select the topic(s) you want to send messages.
Output Keys
See Also
Key Description
time
Event time
source Event type
error.type (Failure port only) Error type
error.message (Failure port only) Error message
