Directory and Account Permissions
Directory View
Directory Required Permissions By the Account that Runs the... Notes
FME Server install directory (<FMEServerDir>) Write FME Server Installer
Read/Write FME Server Core, FME Engines, Web Application Server
FME Server Web Application Server (<WebAppDir>) Write FME Server Installer Applies only to a Distributed/Fault Tolerant Installation of FME Server.
/opt Write FME Server Installer Applies only to FME Server installed on Linux.
FME Server System Share* Write FME Server Installer For a Distributed/Fault Tolerant Installation of FME Server on Linux, you must create an fmeserver account before installation and assign the necessary permissions. For more information, see Provide a Remote File System for the FME Server System Share.
Read/Write FME Engines (account should not be an administrator***)
Read/Write FME Server Web Application Server
FME Server Database Read/Write FME Engines Applies only to a Distributed/Fault Tolerant Installation of FME Server.
Your organization's data for running workspaces Read/Write FME Engines
FME Server Component View
FME Server Component Default Account that Runs this Component (Windows) Default Account that Runs this Component (Linux) Required Permissions
FME Server Installer administrator root Write on FME Server install directory
FME Server Core local system fmeserver**
Read/Write on FME Server System Share* and FME Server install directory
FME Engines local system (should not be changed to an administrator account***) fmeserver**
Read/Write on FME Server System Share*, FME Server Database, and FME Server install directory
FME Server Web Application Server local system fmeserver**
FME Server Database local system fmeserver**
* The FME Server System Share files include Repositories and Resources. By default, an Express Installation of FME Server writes these files to the path specified by the %ALLUSERSPROFILE% environment variable, which defaults to C:\ProgramData\Safe Software\FME Server\. If your Express Installation of FME Server specified a different directory, or if your FME Server is a Distributed/Fault Tolerant Installation, then these files are written to the directory specified.
** On an Express installations, this account is created by the FME Server Installer during installation. On Distributed installations, you must create this account prior to installation. For more information, see Provide a Remote File System for the FME Server System Share.
*** To ensure the integrity of your overall file system, avoid running the FME Engines under an account with local administrator privileges, unless workspaces read or write data that requires a local installation of Esri ArcGIS. These formats require an administrator account to access the ArcGIS license.
