Working with FME Server Container Environment Variables
To perform additional configuration of an FME Server deployment with Docker Compose, define an environment variable section under the relevant container service. Each service has a different set of environment variables that can be defined.
Changing the Database Connection
Note: To configure FME Server to connect to a Microsoft SQL Server or an Oracle database, contact Safe Support.
Initializing the PostgreSQL Database
When a new stack is launched, a mode of the core container populates an empty PostgreSQL database with the FME Server database schema before starting FME Server. If you want to use an existing PostgreSQL database for your FME Server, you must configure an initialization container using the following environment variables.
For example, the following command populates the schema in an existing PostgreSQL database running on host my-psgql-hostname, and then exits.
docker run -e PGSQLHOSTNAME=my-pgsql-hostname -e PGSQLPORT=5432 -e PGSQLADMINUSER=postgres -e PGSQLADMINPASSWORD=postgres -e PRIMARY_PROCESS=initpgsql safesoftware/fmeserver-core:2018-latest
Environment Variable |
Default Value |
Description |
| PGSQLHOSTNAME | fmeserverdb |
The host name of the PostgreSQL database that is to be initialized. |
| PGSQLPORT | 5432 | The port to connect to the PostgreSQL database. |
| PGSQLADMINUSER | postgres | A user that exists on the PostgreSQL database that has permissions to create a database. |
| PGSQLADMINPASSWORD | The password for the PGSQLADMINUSER. | |
| PRIMARY_PROCESS | Set to initpgsql. |
Running the Containers as a Different User
By default, the FME Server containers run as a user named fmeserver in group fmeserver, with UID and GID 1363. You may want the UID and GID of the user in the container to match a user defined on the host machine. For example, you may want to use a host bind mount for the FME Server System Share volume instead of using Docker volumes. If mounting a host directory into the container, it is optimal if the permissions in that folder match a real user on the host.
To match the user and group running a container with a user defined on the host machine, pass in variables FMESERVER_UID and FMESERVER_GID, set to the UID and GID of the user and group ID you want to use, respectively. Additionally, you must run the containers as the root user so that the container init can set the right permissions on the files. This is done in a Docker run command with the --user=0 flag, and in Compose with the attribute user: 0 to run as root.
Running Containers in the Local Time Zone
By default, FME Server containers run in Coordinated Universal Time (UTC). To adjust to the local time zone of the container hosts, mount time zone files to the fmeserverweb, fmeservercore, fmeserverqueue, and fmeserverengine containers, as follows:
volumes:
- "/etc/timezone:/etc/timezone:ro"
- "/etc/localtime:/etc/localtime:ro"
Alternatively, set the TZ environment variable for each container, as follows:
TZ=<timezone>
where <timezone> is a valid country code. For a list of country codes, see https://en.wikipedia.org/wiki/List_of_tz_database_time_zones.
FME Server Web Services Container
Default Value |
Description |
| EXTERNALHOSTNAME | localhost | The host name that users will use to connect to this FME Server. This is commonly the hostname or IP address of the physical machine on which the Docker deployment is running, or the external endpoint of the load balancer. This variable is used for Topic Monitoring. If you do not need to use Topic Monitoring, leave as localhost. |
| EXTERNALPORT | 80 | The port used to connect to the FME Server Web User Interface. This should be the port exposed on the host or load balancer that users will use to connect. |
| FMESERVERHOSTNAME | fmeservercore | The service name or host name of the FME Server Core container. |
| WEBSERVERHOSTNAME | fmeserverweb | The service name or host name of the FME Server Web Services container. |
| WEBPROTOCOL | https | The protocol FME Server uses. Can be either http or https. |
| WEBSOCKETHOSTNAME | fmeserverwebsocket | The service name or host name of the WebSocket server container. |
| LOGPREFIX | The host name of the container | The prefix to use on the log files created by this container. |
FME Engine Container
Default Value |
Description |
| EXTERNALHOSTNAME | localhost | The host name that users will use to connect to this FME Server. This is commonly the hostname or IP address of the physical machine on which the Docker deployment is running. This is used for the data download results URL that is returned after running a job in the Data Download Service. If you don’t use the Data Download service, leave as localhost. |
| EXTERNALPORT | 443 | Port used to connect to FME Server. |
| PGSQLHOSTNAME | fmeserverdb | The service name or host name of the FME Server PostgreSQL database. If you want to use a different database type, see Changing the Database Connection, above. |
| PGSQLPORT | 5432 | The port for the FME Server PostgreSQL database. If you want to use a different database type, see Changing the Database Connection, above. |
| FME_INSTANCE_NAME | The host name of the container | The name of the engine that appears on the Licensing & Engines page. |
| NODENAME | The host name of the container | The host name of the engine that the Core container uses to communicate with this engine. |
FME Server Core Container
Default Value |
Description |
| PGSQLHOSTNAME | fmeserverdb | The service name or host name of the FME Server PostgreSQL database. To use a different database type, see Changing the Database Connection, above. |
| PGSQLPORT | 5432 | The port for the FME Server PostgreSQL database. To use a different database type, see Changing the Database Connection, above. |
| REDISHOSTS | fmeserverqueue | The service name or host name of the Redis queue. |
| REDISPORT | 6379 | The port for the Redis queue. |
| PORTPOOL |
This setting is required only if FME Engines that are not running in Docker are connecting to this FME Server Core. If engines are connecting from outside the docker network, perform the following:
| FIRSTLOGINCHANGEPASSWORD | true | If true, the user will be prompted to update the admin password upon initial login to the FME Server Web User Interface following installation. If false, updating the admin password will not be required upon initial login. |
| MAX_TRANSACTION_RESULT_SUCCESSES | Specifies the number of successful translations until an engine process should be restarted. | |
| MAX_TRANSACTION_RESULT_FAILURES | Specifies the number of failed translations until an engine process should be restarted. | |
| PRIMARY_PROCESS | core | Defines the purpose of this container. Valid values are core, websocket, or initpgsql. Setting to websocket starts only the websocket process. Setting to initpgsql runs the database initialization scripts against the configured database. For more information, see Initializing the PostgreSQL Database, above. |
NGINX Container
Default Value |
Description |
| EXTERNALHOSTNAME | localhost | The host name that users will use to connect to this FME Server. This is commonly the hostname or IP address of the physical machine on which the Docker deployment is running. This variable is used for Topic Monitoring. If you do not need to use Topic Monitoring, leave as localhost. |
| EXTERNALPORT | 443 | The port used to connect to FME Server. |
| NGINX_WORKER_PROCESSES | 1 | Number of NGINX workers to start. |
