WhiteStarLeaseBuilder
Posts a query to a WhiteStar Legal2Map™ WebServices (WS3) server to obtain points or polygons matching a list of legal land descriptions.
A feature is emitted for each point or polygon returned from the query.
Request Parameters
Request Description Attribute
The list attribute on the input feature that provides the set of textual property descriptions which form the request query.
If the list attribute contains a single element, and that element is an integer, it will be assumed to be the transaction ID of a previous query. In this case, a request will be performed to retrieve the results of the query corresponding to the given transaction ID.
Resulting Geometry Type
If Point is specified, the submitted query will result in a set of points representing corresponding well locations. If Polygon is specified, the query will result in a set of polygons representing the area described by the request.
Connection Parameters
Number of times to retry deferred results
Number of times to resend the query if results are not returned after the time specified by Number of seconds to wait between tries.
Note: Queries involving deferred results are not currently supported, and may result in an error.
Web Service Host
The web service host name to send the query to. The query is sent to the web wervice host using basic authentication over an HTTPS connection.
Note: For access outside of your network using a proxy server, use the Network tools in FME Options. From the Workbench menu, select Tools > FME Options > Network. For more information, see "Network" in the FME Workbench Help.
HTTP Authentication Parameters
Example
The query for well locations described by the queries "6 25S 21E 1 SE SE SE NW" and "6 10S 16W 2 C SE NE SW" is formed as follows:
- The input feature contains the attribute request{0} and request{1} with the values:
request{0} = "6 25S 21E 1 SE SE SE NW"
request{1} = "6 10S 16W 2 C SE NE SW"
- "Request Description Attribute" is set to "request{}"
- "Result Description Attribute" is set to "_description"
- "Transaction ID attribute" is set to "_trans_id"
- "Resulting Geometry Type" is set to "Point".
- Web service host, username, and password are entered for the target server.
Execution of this query results in the following two features:
IFMEPoint (-95.052404999999993,37.900077000000003)
_description -> `6 25S 21E 1 SESESENW'
_trans_id -> `871'
fme_geometry -> `fme_point'
fme_type -> `fme_point'
IFMEPoint (-99.076954999999998,39.209764999999997)
_description -> `6 10S 16W 2 CSENESW'
_trans_id -> `871'
How to Set Parameter Values
Text Editor
Arithmetic Editor
Dialog Options - Tables
- Add a row
- Remove a row
- Move current row up one
- Move current row down one
- Move current row to top
- Move current row to bottom
- Cut a row - delete and copy to clipboard
- Copy a row to the clipboard
- Paste a row from the clipboard
Cut, copy, and paste may be used within a transformer, or between transformers.
Start typing a string, and the matrix will only display rows matching those characters. Searches all columns. This only affects the display of attributes within the transformer - it does not alter which attributes are output.
Generally resets the table to its initial state, and may provide additional options to remove invalid entries. Behavior varies between transformers.
