RasterGeoreferencer
Georeferences a raster by either known corner coordinates or origin, cell size, and rotation.
- Adding known position information to rasters.
- Georeferencing rasters with non-spatial content for cartographic purposes.
The RasterGeoreferencer receives raster features and tags them with georeferencing information as provided in the various parameters.
There are two methods of georeferencing available:
| Point and Angle | Georeferences based on the known origin (upper left corner) coordinates, cell spacing (cell size), and rotation. |
| Extents | Georeferences based on the coordinates of all four corners of the raster, which must form a rectangle. |
A CoordinateSystemSetter may be used in conjunction with a RasterGeoreferencer to provide complete position information.
If the raster is already georeferenced, the existing georeferencing information will be overwritten.
In this example, we will georeference a regional image of Africa, which was provided with an accompanying text file containing the extents and coordinate system information.
Note that the original raster does not have any positional information.
To position the image, two transformers will be required. The raster is first routed into a CoordinateSystemSetter where the relevant coordinate system is attached.
The raster is then routed to a RasterGeoreferencer.
In the parameters dialog, Parameter Type is set to Extents, which enables coordinate parameters for all four corners. The corner values were provided with the image, and describe a rectangle.
The output raster’s properties are altered according to the georeferencing information. Note that the extents, origin, cell spacing and affine transform have been newly recalculated.
The georeferenced output raster, shown in the FME Data Inspector with a background map turned on for context:
- Georeferencing does not alter cell values or require interpolation - it only tags the raster with positional information to be interpreted by a product. It differs from reprojection, where the raster itself is transformed from one known coordinate system to another, interpolating new cell values. A Reprojector may be used for this.
Choosing a Raster Transformer
Working with Rasters
| RasterConvolver |
| RasterRotationApplier |
Working with Bands
| RasterBandKeeper |
Working with Cells
| RasterAspectCalculator |
Working with Palettes
| RasterPaletteAdder |
| RasterPaletteNodataSetter |
Workflow Control
| RasterSelector |
Vectors and Rasters
| PointCloudOnRasterComponentSetter | Sets point cloud component values by overlaying a point cloud on a raster. The component values for each point are interpolated from band values at the point location. |
Raster features with provided georeferencing information applied.
INVALID_RASTER_NO_BANDS
| Parameter Type |
Select the georeferencing method. Remaining parameters will be enabled or disabled based on the type chosen. Point And Angle: Georeference by specifying the origin (upper left corner) coordinates, cell spacing (size of the cells in ground units), and rotation angle. Extents: Georeference by specifying the coordinates for all four corners of the raster. The coordinates provided must form a rectangle, and will be validated. Rotation and cell spacing will be derived from these values. |
| X Upper Left Coordinate
Y Upper Left Coordinate |
For both Point and Angle and Extents georeferencing, enter the upper left (origin) coordinates. |
| X Cell Spacing
Y Cell Spacing |
For Point and Angle georeferencing, enter the cell size in ground units. |
| Rotation (degrees) | For Point and Angle georeferencing, enter the rotation angle in degrees. |
| X Upper Right Coordinate
Y Upper Right Coordinate |
For Extents georeferencing, enter the upper right coordinates. |
| X Lower Right Coordinate
Y Lower Right Coordinate |
For Extents georeferencing, enter the lower right coordinates. |
| X Lower Left Coordinate
Y Lower Left Coordinate |
For Extents georeferencing, enter the lower left coordinates. |
Dialog Options - Tables
Search for all results about the RasterGeoreferencer on the FME Community.
Contains information licensed under the Open Government Licence – Canada.
