MultipleGeometrySetter
Provides the ability to set up an aggregate where each part is independent from the others, and its own complete geometry.
For example, if an aggregate enters and it contains two parts, a line and a polygon, it will leave containing the same two parts, but the difference will be that each part should now be interpreted as its own separate geometry. For example, a database writer that supports this concept may then write out each of the multiple geometries to its own geometry column.
About Multiple Geometry
Aggregate
Aggregates will be sent out via the Aggregate port.
<Rejected>
This transformer works only on aggregates, so features containing any other geometry type will be sent to the <Rejected> output port.
Set to Contain Multiple Geometries
When this parameter is set to No, the aggregate will represent a single geometry comprising multiple parts
When this parameter is set to Yes, each part in the aggregate will be interpreted as its own separate geometry, independent from the other parts.
How to Set Parameter Values
Text Editor
Arithmetic Editor
Dialog Options - Tables
- Add a row
- Remove a row
- Move current row up one
- Move current row down one
- Move current row to top
- Move current row to bottom
- Cut a row - delete and copy to clipboard
- Copy a row to the clipboard
- Paste a row from the clipboard
Cut, copy, and paste may be used within a transformer, or between transformers.
Start typing a string, and the matrix will only display rows matching those characters. Searches all columns. This only affects the display of attributes within the transformer - it does not alter which attributes are output.
Generally resets the table to its initial state, and may provide additional options to remove invalid entries. Behavior varies between transformers.
Transformer History
This transformer was previously named IndividualGeometriesSetter.
Keywords: aggregate individual multiple many "multiple geometry" multigeometry IndividualGeometriesSetter
