LatLongToMGRSConverter
Calculates a Military Grid Reference System (MGRS) code based on the latitude and longitude values supplied in a feature's attributes.
The granularity of the resulting code is determined by the specified Precision which is an integer from 0 to 5 (inclusive). A precision of 5 locates a point within a 1-meter square and precision of 0 locates a point within 100-km square.
The result of the conversion is stored in the MGRS Code Attribute of the feature.
Dialog Options - Tables
FME Licensing Level
