GeometryExtractor
Extracts the geometry of a feature according to the setting of the geometry encoding parameter.
The resulting encoded geometry is added to the feature in an attribute. This attribute can later be restored as the feature's geometry via the GeometryReplacer transformer.
This transformer is often used to make a copy of the feature's geometry into an attribute before some temporary geometry change is made, so that it can later be restored. Alternately, the geometry may be extracted to be stored in a database or other file format that cannot handle geometry, but can handle large attributes as blobs or text strings. Later, FME can read this data back and restore the geometry via the GeometryReplacer transformer.
Note: Feature order may change in relation to other output ports. Feature order per port is maintained.
Encoded Polyline Parameters
Geohash Parameters
GML/KML Parameters
JSON Parameters
OGC Parameters
MGRS Parameters
MS SQL Server Parameters
ISO 6709 Geographic Point Parameters
GeometryExtractor does not perform any repairs to feature geometries during extraction. Geometries are extracted in their current state.
To carry out a similar operation on raster data, please use the RasterExtractor transformer. For point cloud data, please use the PointCloudExtractor.
Be sure to position this transformer as close as possible to where the geometry attribute is being used. Positioning the transformer too early can cause unnecessary use of system resources.
Dialog Options - Tables
FME Licensing Level
Transformer History
This transformer contains the functionality of the now-deprecated OGCGeometryExtractor and XMLGeometryExtractor.
