Retrieves the value of all the feature's coordinates into an attribute, separated by the delimiter characters.
 Coordinate Delimiter
                                                This parameter can contain either an arbitrary string or a character, which is inserted between each coordinate set.
 Coordinate Element
 Delimiter
Coordinate Element
 Delimiter
                                                This parameter can also contain either an arbitrary string or a character, which is inserted between each x/y/z element of each coordinate.
Characters can be expressed as regular characters but they can also include any number of control characters.
Special character sequences are interpreted as shown below:
| Sequence | Description |
| Ctrl+Shift+h (^H) | Backspace (0x08) |
| Ctrl+Shift+l (^L) | Form feed (0x0c) |
| Ctrl+Shift+j (^J) | Newline (0x0a) |
| Ctrl+Shift+r (^M) | Carriage return (0x0d) |
| Ctrl+Shift+i (^I) | Tab (0x09) |
| Ctrl+Shift+k (^K) | Vertical tab (0x0b) |
Defining Special Characters
You can define special characters through the Text Editors. Click Open Text Editor from the parameter menu:
Text Editor
Enter characters using the shortcuts from the table above.
Note: To see tab characters, click the Options menu on the bottom left and select Show Spaces/Tabs.
 Coordinate Element(s) to Include
                                                This parameter specifies which elements in the coordinate to output. For example, if the coordinate has a value of Z, only the z coordinate will be output.
 Coordinate Attribute
                                                This attribute stores the value of the feature's coordinates.
- This transformer works only for point, line, area, and donut features. Aggregate features will give invalid values.
- If Coordinate Element(s) to Include contains Z and the features contain two-dimensional data, only the x and y coordinates will be stored.
Using a set of menu options, transformer parameters can be assigned by referencing other elements in the workspace. More advanced functions, such as an advanced editor and an arithmetic editor, are also available in some transformers. To access a menu of these options, click  beside the applicable parameter. For more information, see Transformer Parameter Menu Options.
 How to Set Parameter Values
 Content Types
Content Types
| Special Characters | A set of control characters is available in the Text Editor. |
Dialog Options - Tables
                                                | Row Reordering
        | Enabled once you have clicked on a row item. Choices include:
| Cut, Copy, and Paste
| Filter
        | Start typing a string, and the matrix will only display rows matching those characters. Searches all columns. This only affects the display of attributes within the transformer - it does not alter which attributes are output. |
| Import
        | Import populates the table with a set of new attributes read from a dataset. Specific application varies between transformers. |
| Reset/Refresh
        | Generally resets the table to its initial state, and may provide additional options to remove invalid entries. Behavior varies between transformers. |
