Microsoft Access (JDBC) Reader/Writer
Licensing options for this format begin with FME Desktop Professional Edition.
Overview
The Microsoft Access (JDBC) reader and writer modules provide FME with access to attribute data held in Microsoft Access database tables.
The performance of this format is dependent on the amount of memory allocated to the Java Virtual Machine (JVM). The following environment variables allow you to specify memory available to Java Plugins:
  • FME_JVM_MIN_HEAP_SIZE: Initial heap size for initializing the JVM. If unset, the default value is 1024K.
  • FME32_JVM_MIN_HEAP_SIZE: Same as FME_JVM_MIN_HEAP_SIZE, but applies to 32-bit FME Desktop on Windows, and if set, takes precedence over FME_JVM_MIN_HEAP_SIZE.
These variables must be set in multiples of 1024 and greater than 1 MB. To indicate kilobytes, megabytes, or gigabytes, append k or K, m or M, or g or G, respectively. For example, any of these values is acceptable:
6291456
6144k
6m
  • FME_JVM_MAX_HEAP_SIZE: Maximum heap size for initializing the JVM. If unset, the default value is 16384K.
  • FME32_JVM_MAX_HEAP_SIZE: Same as FME_JVM_MAX_HEAP_SIZE, but applies to 32-bit FME Desktop on Windows, and if set, takes precedence over FME_JVM_MAX_HEAP_SIZE.
These variables must be set in multiples of 1024 and greater than 2 MB. To indicate kilobytes, megabytes, or gigabytes, append k or K, m or M, or g or G respectively. For example, any of these values is acceptable:
83886080
81920k
80m
Note: To pass additional parameters used by FME to the Java Virtual Machine, use the JAVA_TOOL_OPTIONS environment variable.
Workbench Reader Overview
Click the Reader Parameters button and establish a Microsoft Access database connection.
Workbench Writer Overview
Click the Writer Parameters button and establish a Microsoft Access database connection.
The Microsoft SQL Server writer module stores attribute records into a live relational database. The Microsoft SQL Server writer provides the following capabilities:
  • Transaction Support: The Microsoft SQL Server writer provides transaction support that eases the data loading process. Occasionally, a data load operation terminates prematurely due to data difficulties. The transaction support provides a mechanism for reloading corrected data without data loss or duplication.
  • Table Creation: The Microsoft SQL Server writer uses the information within the workspace to automatically create database tables as needed.
FME Community
Search for articles about Microsoft Access JDBC.
