Amazon SQS Message Received
The Amazon SQS (Simple Queue Service) trigger polls an Amazon SQS queue for messages. For more information about the Amazon SQS, see the Amazon SQS Getting Started Guide.
Requirements
To use the Amazon SQS trigger, you need:
  • Amazon Web Services (AWS) security credentials.
  • Permission to receive messages from the queue you want to poll.
  • The URL of the queue you want to poll. If you own the queue, you can find this information by navigating to your queue through the AWS Management Console (see image, below). Otherwise, ask the queue owner for the URL.
  • Mouse-over to view image:
Note: See also Working with Parameters in Automations Workflows.
Tip: To test that your parameters work as expected, click Validate.
  • SQS Queue URL: Provide the URL of the queue.
  • AWS Access Key ID and AWS Secret Access Key: Provide your AWS security credentials.
  • Delete Message After Received: If Yes, the trigger deletes the Amazon SQS message from FME Server after it is published. If No, the trigger does not delete the message. (Instead, a corresponding process is responsible for deleting it.)
  • Visibility Timeout: The time, in seconds, beginning when the trigger starts, during which other SQS triggers cannot access the same message from the Amazon SQS queue.
Output Keys
See Also
Key Description
message Message content
sqs.md5 Message MD5 digest
sqs.messageId Message ID
sqs.receipt Message receipt handle
source Event type
time Event time
