Upload to SFTP Server
The SFTP external action receives messages and uploads files over a Secure Shell (SSH) connection to specified SSH File Transfer Protocol (SFTP) hosts.
The SFTP external action has two output ports. The success port (✔) can send a message if the upload is successful. The failure port (x) can send a message if the upload fails.
Note: See also Working with Parameters in Automations Workflows.
Tip: To test that your parameters work as expected, click Validate.
- Host: The SFTP host name.
- Port: The SFTP port number. The default is 22.
- Username: The SFTP user name for authentication.
- Password: The SFTP user password for authentication.
- Verify Host Keys: Whether or not to verify the host key for the server connection.
- Path to Known Hosts File: If Verify Host Keys is Yes, the path to the known_hosts file that contains the public keys for any servers you wish to connect to. If the known_hosts file is saved to a Resources directory, click the ellipsis (...) and select the file. Otherwise, enter the file path directly. File paths must use forward slashes (/) or escaped backslashes (\\).
- Destination Path: The destination path to upload the file.
- Source Path: The source file to upload. If the source file is saved to a Resources directory, click the ellipsis (...) and select the file. Otherwise, enter the file path directly. File paths must use forward slashes (/) or escaped backslashes (\\).
Note: A known_hosts file contains public keys for computers you connect to via SSH. To obtain a public key and insert it into the known_hosts file, run the following command in OpenSSH: ssh-keyscan -t rsa <hostname> > <path_to_known_hosts_file>. Alternatively, contact your system administrator.
For more information about OpenSSH, and to install, see http://www.openssh.com/.
Example
Mouse-over to view:
Output Keys
See Also
Tip: To view the output keys from upstream components, click Show Upstream Keys.
| Key | Description |
| time | Event time |
| source | Event type |
| file.path | (Success port only) File path |
| error.type | (Failure port only) Error type |
| error.message | (Failure port only) Error message |
