EnvironmentVariableFetcher
Fetches the specified environment variable and includes it in a new attribute.
Environment variables are convenient especially if certain standard folders and parameters need to be referenced in a workspace, but the actual locations or names can vary from computer to computer.
The available variables will depend on which platform you are using. For example in Windows you can find a list of variables on your system by opening Control Panel > System > Advanced > Environment Variables.
Within an FME workspace you could use the value retrieved to:
  • Define the output location of a dataset (in conjunction with Feature Type Fanout, which is described in the Workbench help files)
  • Define the location of a file for the AttributeFileWriter or AttributeFileReader
  • Define the location of a workspace to run with the WorkspaceRunner
  • Write the value to some type of metadata output
Dialog Options - Tables
Transformer History
This transformer has been renamed from EnvironmentVariableRetriever.
Keywords: EnvironmentVariableRetriever
