Allowed Projection Types
Each coordinate system definition must specify a projection type and
provide values for all of the parameters associated with the projection.
The table below lists the projection types allowed in coordinate system
definitions.
Notes
- All latitudes and longitudes
provided as projection parameters must be given in degrees. Negative values
are used to indicate southern latitude and western longitude.
- All longitude
values must be given relative to the Greenwich Prime Meridian.
- False origins are always given
in the units of the coordinate system.
Projection Type |
Description |
AE |
Albers Equal Area
AZMEA |
Lambert Azimuthal Equal Area
AZMED |
Lambert Azimuth Equidistant
AZMED-ELEV |
Lambert Azimuthal Equidistant, Elevated Ellipsoid
BIPOLAR |
Bipolar Oblique Conformal Conic
BONNE |
Bonne
CASSINI |
Cassini
ECKERT4 |
Eckert 4
ECKERT6 |
Eckert 6
EDCNC |
Equidistant Conic
EDCYL |
Equidistant Cylindrical
EDCYL-E |
Equidistant Cylindrical Projection (Ellipsoidal or Spherical)
GAUSSK |
Gauss Kruger Projection, aka Gauss
GEOCENTRIC_FME |
Geocentric
GNOMONIC |
Gnomonic
GOODE |
Good Homolosine
HOM1UV |
Hotine Oblique Mercator – one point, unrectified
HOM1XY |
Hotine Oblique Mercator, Alaska Variation
HOM2UV |
Hotine Oblique Mercator – two points, unrectified
HOM2XY |
Hotine Oblique Mercator – two points, rectified
KROVAK |
Krovak Oblique Conformal Conic, Czechoslovkia
KROVAK95 |
Krovak Oblique Conformal Conic, Czechoslovkia, 1995 Adjustment
LL |
Latitude/Longitude
LM |
Lambert Conformal Conic
LM1SP |
Lambert Conformal Conic Projection, One Standard Parallel
LMAF |
Lambert Conformal Conic (2SP) with Affine Post Process
LMBLGN |
Lambert Conformal Conic Projection, Belgian Variation
LM-MNDOT |
Lambert Conformal Conic, Minnesota DOT Variation
LMTAN |
Lambert Tangential
LM-WCCS |
Lambert Conformal Conic, Wisconsin County Variation
MILLER |
Miller Cylindrical
MODPC |
Modified Polyconic
MOLLWEID |
Mollweide Projection
MRCAT |
Mercator Cylindrical Projection with Standard Parallel (Traditional)
MRCAT-PV |
Popular Visualisation Pseudo Mercator
MRCATK |
Mercator Cylindrical Projection with Scale Reduction
MSTERO |
Modified Stereographic
NEACYL |
Normal Aspect Equal Area Cylindrical
NERTH |
NonEarth
NERTH-SRT |
NERTH-SRT
NZEALAND |
New Zealand National Grid
OBQCYL |
Oblique Cylindrical
ORTHO |
Orthographic
OSTERO |
Oblique Stereographic (International)
OSTEROUS |
Oblique Stereographic (per Snyder USA)
OSTN02 |
ETRF89 Referenced OSGB
OSTN97 |
ETRF89 Referenced OSGB (ETRF89<-->OSGB via OSTN97)
PCARREE |
Plate Carree / Simple Cylindrical
PLYCN |
American Polyconic
PSTERO |
Polar Stereographic Projection
PSTEROSL |
Polar Sterographic with Standard Latitude Projection
ROBINSON |
Robinson
RSKEW |
Rectified
Skew Orthomorphic, Azimuth at Projection Center
RSKEWC |
Rectified
Skew Orthomorphic, Origin and Azimuth at Center
RSKEWO |
Rectified
Skew Orthomorphic, Skew Azimuth at Rectified Origin
SINUS |
Sinusoidal
SOTM |
South-Oriented Transverse Mercator
SWISS |
Swiss Oblique Cylindrical Projection
SYSTM34 |
Danish System 34, UTM + polynomials (pre-1999 vintage)
SYSTM34-01 |
Danish System 34, UTM + polynomials (2001 vintage)
SYSTM34-99 |
Danish System 34, UTM + polynomials (1999 vintage)
TEACYL |
Transverse Aspect Equal Area Cylindrical
TM |
Transverse Mercator
TMAF |
Transverse Mercator (Gauss/Kruger) with Affine Post Process
TM-MNDOT |
Transverse Mercator, Minnesota DOT Variation
TM-SNYDER |
Transverse Mercator per J. P. Snyder
TM-WCCS |
Transverse Mercator, Wisconsin County Variation
TRMRKRG |
Transverse Mercator using Kruger Formulation
UTM |
Universal Transverse Mercator System
VDGRNTN |
Van Der Grinten
SourceSansPro-Black.ttf
SourceSansPro-BlackItalic.ttf
SourceSansPro-Bold.ttf
SourceSansPro-BoldItalic.ttf
SourceSansPro-ExtraLight.ttf
SourceSansPro-Italic.ttf
SourceSansPro-LightItalic.ttf
SourceSansPro-Regular.ttf
SourceSansPro-SemiBold.ttf
SourceSansPro-SemiBoldItalic.ttf
Hasklig-Regular.otf
OpenSans-Regular.ttf
