Server Apps
Select Server Apps > Manage Apps.
Use the Server Apps page to create and manage FME Server "apps" that run workspaces from a web browser.
When you create an FME Server app to run a workspace, FME Server generates a URL for the workspace, along with a security token. The token allows anyone with the URL to run the workspace and configure published parameters, without authenticating to FME Server.
Note: Once created, security tokens can be accessed on the API Tokens tab of the Token Management page.
Tip: Server Apps provide some Progressive Web App (PWA) features, such as Add to Home Screen (A2HS). For more information, see this FME Community article.
By default, all apps are enabled to run when created. Disabled apps do not run, even if their tokens are not expired. To disable or enable an app, select an app, then select Actions > Disable or Enable.
From the Actions menu, you can also Remove an app or Change Expiration of an app.
To view and run an app, or copy an app's URL, click the View or URL icon of the corresponding app, respectively.
To Create an FME Server App
- Click Create or select Server Apps > Build App. Alternatively, to duplicate an existing app and revise, select an app, and select Actions > Duplicate. The Create Server (or Duplicating) App dialog opens. Complete or update the following:
- Name: Provide a name for the app. The name appears on the run page for the app. App names are case-insensitive.
- Description (optional): Provide a description for the app. The description appears on the run page for the app. Use the toolbar widgets to customize the appearance of the description, as desired.
- Repository: The repository of the workspace you want the app to run.
- Workspace: The workspace you want the app to run.
- Service: An FME Server service that the workspace is registered to run.
- Expiration: The expiration date and time of the security token of the app. After the token expires, the app will not run. The default expiration is 10 years from the current date.
- Require Authentication: If enabled, access to the app is restricted to designated Users or Roles in FME Server. Designated users must first log in to FME Server with their username and password before access is granted. Access is denied to all others. To enable, click the slider. Click inside the Allowed Users box to add the users and roles you want to grant access.
- User Can Upload: If the workspace uses the Data Upload Service, this setting allows users to upload temporary files that are used to run the workspace.
- Additional Permissions: The security token that FME Server generates for the app is configured with the minimal set of permissions to run the specified workspace. However, if this setting appears, other permissions may still be required. You may need to further test and adjust the given permissions.
- Access: Access the Run Workspace page.
- Advanced: Access Job Directives when running workspaces.
- Access: Access the Jobs page to view the jobs you have run, or cancel any of your jobs that are currently running or in queue.
- Manage: Access and manage the jobs of all users. You can:
- Cancel any job that is currently running.
- Remove the history of jobs that were previously run.
- Manage Job Queues. (Also requires Manage permission in Licensing & Engines.)
- Access: Access the Automations page.
- Create: Create workflows.
- Read: View a workflow and its log file.
- Write: Edit or remove a workflow.
- Run: Start and stop a workflow.
- Access: Access the Schedules page.
- Create: Create schedules.
- Full Access: Edit or delete a schedule.
- Access: Access the Workspaces page.
- Create: Create repositories.
- Download: Download workspaces and other repository items from FME Server into Workbench.
- Read: View repository information.
- Publish: Publish workspaces and other items to the repository from Workbench.
- Run: Run repository workspaces from FME Server.
- Remove: Remove a repository, or remove items from a repository.
- Access: Commit versions and view repository history.
- Manage: Enable version control and configure with a remote Git repository.
- Access: Access the Workspaces.
- Access: Access the Server Apps page.
- Create: Create new FME Server apps.
- Run: Run an FME Server app.
- Read: Access an FME Server app.
- Write: Edit or Remove an FME Server app.
- Access: Access the Publications page.
- Create: Create Notification Service Publications.
- Read: View information about a publication.
- Write: Edit a publication.
- Remove: Delete a publication.
- Access: Access the Subscriptions page.
- Create: Create Notification Service Subscriptions.
- Read: View information about a subscription.
- Write: Edit a subscription.
- Remove: Delete a subscription.
- Access: Access the Topics page.
- Create: Create topics.
- Read: View information about a topic.
- Write: Edit a topic.
- Publish: Publish notifications to a topic.
- Remove: Delete a topic.
- Access: Access the Resources page.
- Create: Create connections to network resources.
- Access: Read and download a file.
- List: List the folders and files of a resource.
- Write: Write to files.
- Upload: Upload files.
- Remove: Delete files.
- Access: Access the Database Connections and Web Connections pages.
- Create: Create connections.
- Manage: Access, create, and remove connections.
- Access: Manage web services.
- Access: Access the Projects page.
- Create: Create projects.
- Read: View information about a project.
- Write: Edit a project.
- Delete: Delete a project, or delete items from a project.
- Access: Access the Dashboards page.
- Manage: Configure licensing and engines, except job queues (requires Manage permission in Jobs).
- Manage: Configure users and roles, and manage Cross-Origin Resource Sharing.
- Manage: Configure system cleanup.
- Access: Access the /metrics endpoint of the FME Server REST API.
- Manage: Configure the FME Server services.
- Full Access: Manage FME Server services.
- Manage: Configure System Events.
- Upload: Allow publishing FME packages from FME Desktop to FME Server.
- Parameters: If the workspace has published parameters, configure the default values for each one when the app runs.
- Show in App: If checked, the app allows the user to explicitly specify a value for the parameter, or accept the default value. If unchecked, the app page does not display the parameter, and the app runs according to its default value.
- Customize (optional): You can customize various elements of the run page for the app, including Title, Background Color, Heading Image, and Icon. Alternatively, to specify that the app should run as soon as its URL is invoked, without displaying a run page, enable Run Immediately.
- Click OK. A message appears to indicate the app is created, along with the app URL. Click the Copy icon to copy the URL. To run the app, click the URL. When finished, click OK. The Server App page re-opens and lists your new app.
Note: The following is a complete list of permissions in FME Server. Under Additional Permissions, only the minimal additional permissions that may be required to run the workspace display. After the token is generated, you can configure additional permissions for it on the Token Management page.
Individual Automations:
Note: Automations requires additional permissions. You are prompted to grant any additional permissions that are required.
Individual Schedules:
Note: Access permission is not required to run a workspace. Only Run permission on the applicable repository is required (see below).
Individual Repositories:
Note: Users must also have Allow permission on the applicable service (see Services) when running workspaces.
Note: You must uncheck all five permissions to completely remove a role from membership with a repository.
Note: Version Control must be enabled to view these permissions.
Individual Server Apps:
Individual Publications:
Individual Subscriptions:
Individual Topics:
Individual Resource connections (top-level folders):
Individual Connections:
Individual Projects:
Note: Access or Create permission is not required to have Read/Write/Delete permission on individual projects. These tasks can still be accomplished with the REST API.
Individual Services:
To revert to the original default values of the workspace, click Reset.
Note: If the workspace is republished to FME Server with new default values for published parameters, the values specified for this app are not affected, unless you click Reset.
