Email Received (IMAP)
The Email Received (IMAP) trigger receives email messages from an IMAP server.
Note:
IMAP access must be enabled on the email account that is polled for messages.
Each IMAP trigger created on FME Server must reference a unique email account. You cannot create multiple IMAP triggers that reference the same address.
Note: See also Working with Parameters in Automations Workflows.
Tip: To test that your parameters work as expected, click Validate.
- IMAP Server Host: Provide the host name or IP address of the IMAP server.
- Gmail: imap.gmail.com
- Outlook (Live and Hotmail): imap-mail.outlook.com
- Yahoo: imap.mail.yahoo.com
- AOL: imap.aol.com
- IMAP Server Port: Provide the TCP port over which IMAP communication takes place.
- IMAP Email Account/Password: Provide the email address and password of the account receiving emails over IMAP.
- Connection Security: Specify the encryption mechanism to use for the IMAP connection. The mechanism selected must work over the specified port.
- Verify SSL Certificate: If Yes, the connection to the specified IMAP Server Host is verified with a valid, signed SSL certificate. If No, the connection is not verified with an SSL certificate. This option is not secure and not recommended unless absolutely necessary, such as when using a self-signed certificate.
- Poll Interval:Specify how often, in minutes, to poll the IMAP server for email.
- Emails to Fetch: If New Emails Only is selected, the publisher fetches only unread messages that were received after the last fetch. If Unread Emails is selected, the publisher fetches every unread email message in the in-box.
- Filter Type: Allows you to fetch only the messages specified by the filter, based on content in the subject line. Filter Type can be:
- Simple: A specified string (case-insensitive).
- Regex: A regular expression. For information about creating regular expressions, see https://docs.oracle.com/javase/7/docs/api/java/util/regex/Pattern.html.
- Subject Filter: Provide the filter, according to the specified Filter Type. Wildcard characters are not supported. If blank, no filter is applied, and all unread/new messages are fetched.
- Download Attachments To: Specify a location to download any attachments.
- Select a Resources folder (...).
- Enter your own location. Directory paths must use forward slashes (/) or escaped backslashes (\\).
Note: IMAP access must be enabled in the account settings.
Protocol | Default TCP Port |
SSL/TLS | 993 |
StartTLS | 143 |
None | 143 |
Note:
Note: When the IMAP server is polled, every unread email in the in-box is marked as read, regardless of this setting.
Output Keys
See Also
Key | Description |
email.subject | Email subject |
email.body | Email body |
email.attachment |
Email attachment Note: If the email contains multiple attachments, this key accesses only the first attachment. To access multiple attachments, use email.attachments instead. |
email.attachments | Path to directory containing all email attachments |
email.sent | Time sent |
email.received | Time received |
email.from | Sent from address |
email.to | Sent to address |
email.contentType | Email body content type |
source | Event type |
time | Event time |
