Notify an FME Server Topic
You can designate FME Server Notification Service Topics to receive messages.
The Notify FME Server Topic external action has two output ports. The success port (✔) can send a message if the topic is notified successfully. The failure port (x) can send a message if the notification fails.
Note: Use the FME Server Topic external action only to terminate a workflow, or a portion of a workflow. It is otherwise not necessary to explicitly define FME Server topics for a workflow to run.
Note: See also Working with Parameters in Automations Workflows.
- Topics: Select the FME Server topic(s) you want to receive messages.
- Message: Specify a message to associate with the FME Server topic(s). If specified, this message replaces the incoming message.
Output Keys
See Also
Tip: To view the output keys from upstream components, click Show Upstream Keys.
| Key | Description |
| time | Event time |
| source | Event type |
| error.type | (Failure port only) Error type |
| error.message | (Failure port only) Error message |
