Microsft Excel (XLSXR/XLSXW) Geometry Support
See Also
Geometry
Supported?
Notes
Aggregates (IFMEAggregate) No
Arcs (IFMEArc)
No
Boxes (IFMEBox) No
BRep Solids (IFMEBRepSolid) No
Clothoids (IFMEClothoid)
No
Composite Solids (IFMECompositeSolid) No
Composite Surfaces (IFMECompositeSurface) No
Coordinate Precision None Non-spatial format
CSG Solids (IFMECSGSolid) No
Donuts (IFMEDonut)
No
Ellipses (IFMEEllipse)
No
Extrusions (IFMEExtrusion) No
Faces (IFMEFace) No
Geometry Definitions and Instances No
Georeferencing None Non-spatial format
Hierarchical Geometries No
Homogeneous Aggregates No
Lines (IFMELIne)
No
Measures No
Meshes (IFMEMesh) No
MultiArea (IFMEMultiArea)
No
MultiCurve (IFMEMultiCurve)
No
Multiple Geometries No
MultiPoint (IFMEMultiPoint)
No
MultiSolid (IFMEMultiSolid) No
MultiSurface (IFMEMultiSurface) No
MultiText (IFMEMultiText)
No
Nulls (IFMENull)
Yes Non-spatial format
Oriented Arcs (IFMEOrientedArc)
No
Paths (IFMEPath)
No
Point Clouds (IFMEPointCloud) No
Points (IFMEPoint)
No
Polygons (IFMEPolygon)
No
Rasters (IFMERaster) No
Rectangle Faces (IFMERectangleFace) No
Surface Normals No
Surface Sidedness No
Text (IFMEText)
No
Textures No
Traits No
Triangle Fans (IFMETriangleFan) No
Triangle Strips (IFMETriangleStrip) No
Z values No
