Installing FME Desktop from the Windows Command Prompt
We recommend installing FME Desktop using the installation wizard. However, installing from the command prompt may be useful when you want to perform a silent or remote installation.
Preparation
When performing a silent installation of FME Desktop, keep in mind the following:
Syntax for Silent Installation
msiexec /i <path_to_installer> /qb INSTALLLEVEL=3 INSTALLDIR="<installdir>" ENABLE_POST_INSTALL_TASKS=no
Example:
msiexec /i fme_beta.msi /qb INSTALLLEVEL=3 INSTALLDIR="C:\Program Files\FME" ENABLE_POST_INSTALL_TASKS=no
Note: INSTALLLEVEL=3 must always be specified when installing silently from the command line.
Post-Install Tasks
Licensing FME Desktop from the Windows Command Prompt
MSSQL Formats Only
