Replaces the geometry of the feature with a label point.
The insertion point of the text is guaranteed to be inside (in case of polygons) or on (lines and points) the original object. Note that since the text itself may be larger than an input area feature, the bounds of the label may exceed the bounds of the area.
Input features must have the correct geometry: point, line or area.
The features with the replaced geometry are output via this port.
Invalid features are output via this port.
Rejected features will have an fme_rejection_code attribute with one of the following values: EXTRA_FEATURE, INVALID_GEOMETRY_TYPE, INVALID_GEOMETRY_VERTICES.
The label to add to the geometry.
The label height is measured in ground units, and may either be entered as a number, or can be taken from the value of a feature attribute by selecting the attribute name from the pull-down list.
The label is rotated to prevent it from appearing upside down.
To generate a point that will be used as a centroid for polygons, use an CenterPointReplacer. This saves you the overhead of having a text object.
Associated FME function or factory: @GeneratePoint, PIPComponentsFactory
Keywords: LabelPointCreator TextReplacer
