Licensing options for this format begin with FME Professional Edition.
The Teradata Spatial reader and writer modules provide FME with access to attribute data held in Teradata database tables. FME provides read and write access via Teradata’s JDBC driver, which must be installed separately.
Downloading the JDBC Driver
Note: For best results, use the JDBC driver that matches the version of the software being communicated with.
You can download the driver from: http://downloads.teradata.com/download/connectivity/jdbc-driver. Teradata's download typically contains two files:
- terajdbc4.jar
- tdgssconfig.jar
Installing the JDBC Driver
To view instructions for installing the JDBC driver, please see Getting Started with JDBC.
The performance of this format is dependent on the amount of memory allocated to the Java Virtual Machine (JVM). The following environment variables allow you to specify memory available to Java Plugins:
- FME_JVM_MIN_HEAP_SIZE: Initial heap size for initializing the JVM. If unset, the default value is 1024K.
                                                FME32_JVM_MIN_HEAP_SIZE: Same as FME_JVM_MIN_HEAP_SIZE, but applies to 32-bit FME Desktop on Windows, and if set, takes precedence over FME_JVM_MIN_HEAP_SIZE.
These variables must be set in multiples of 1024 and greater than 1 MB. To indicate kilobytes, megabytes, or gigabytes, append k or K, m or M, or g or G respectively. For example, any of these values is acceptable:
6291456
6144k
6m
- FME_JVM_MAX_HEAP_SIZE: Maximum heap size for initializing the JVM. If unset, the default value is 16384K.
                                                FME32_JVM_MAX_HEAP_SIZE: Same as FME_JVM_MAX_HEAP_SIZE, but applies to 32-bit FME Desktop on Windows, and if set, takes precedence over FME_JVM_MAX_HEAP_SIZE.
These variables must be set in multiples of 1024 and greater than 2 MB. To indicate kilobytes, megabytes, or gigabytes, append k or K, m or M, or g or G respectively. For example, any of these values is acceptable:
83886080
81920k
80m
Note: To pass additional parameters used by FME to the Java Virtual Machine, use the JAVA_TOOL_OPTIONS environment variable.
