NMEA 0183 Feature Types
track_points
Geometry type: fme_point
Feature Attribute Description
course Course of travel, in degrees. Exposed for reading only.
ele Elevation in meters.
fix
Type of GPS fix. Valid values are
none
2d
3d
dgps
pps
hdop Horizontal dilution of precision.
pdop Position dilution of precision.
sat Number of satellites.
speed Speed of travel, in knots. Exposed for reading only.
time
Creation date and time.
Note that while the NMEA 0183 format supports milliseconds, the NMEA Reader currently does not have support for reading milliseconds. Milliseconds are rounded to the nearest second.
Format:
YYYYMMDDHHMMSS
track_fid
ID of the track feature to which the point belongs.
track_seg_id
ID of the track segment to which the point belongs.
track_seg_point_id
ID of the point.
vdop Vertical dilution of precision.
tracks
Geometry type: fme_aggregate of lines
There are no attributes specific to tracks. The reader exposes tracks as a convenience only.
waypoints
cmt Comment for the waypoint.
desc
Description of the waypoint.
ele
Elevation, in meters.
name
Name of the point waypoint (6 characters maximum). If the name is too long, GPSBabel attempts to reduce the length to 6 characters first by removing vowels and spaces, and then by truncating the name.
If not provided, the name is WPTXXX, where XXX is an auto-incrementing counter.
If names are not unique, duplicate names will be created by replacing the last two characters with x, where x is an auto-incrementing counter.
sym
Name of the symbol for the point. If not provided, the default is “Waypoint”. The name must be a recognized Garmin icon name. “Bell” is used for unrecognized symbol names.
For a list of valid symbol names, refer to garmin_tables.c in the GPSBabel source code. The source for GPSBabel is available at http://www.gpsbabel.org.
time Creation date/time, in UTC
