Esri Geodatabase Quick Facts
About Quick Facts Tables
Esri Geodatabase Geometry Support
Format Type Identifier
  • GEODATABASE_SDE – Esri Geodatabase (ArcSDE Geodb)
  • GEODATABASE_MDB – Esri Geodatabase (Personal Geodb)
  • GEODATABASE_FILE – Esri Geodatabase (File Geodb)
  • GEODATABASE_SDE_RASTER_DATASET – Esri Geodatabase (ArcSDE Geodb Raster Dataset)
  • GEODATABASE_FILE_RASTER_DATASET – Esri Geodatabase (File Geodb Raster Dataset)
  • GEODATABASE_SDE_RASTER_CATALOG – Esri Geodatabase (ArcSDE Geodb Raster Catalog)
  • GEODATABASE_FILE_RASTER_CATALOG – Esri Geodatabase (File Geodb Raster Catalog)
  • GEODATABASE_SDE_MOSAIC_DATASET – Esri Geodatabase (ArcSDE Geodb Mosaic Dataset)
  • GEODATABASE_FILE_MOSAIC_DATASET – Esri Geodatabase (File Geodb Mosaic Dataset)
Reader/Writer
Both
Licensing Level,
Operating System Restrictions
Format Licensing Level Available On
Base Edition
  • Win 32-bit
  • Win 64-bit
Professional Edition
  • Win 32-bit
  • Win 64-bit
Base Edition
  • Win 32-bit
  • Win 64-bit
  • Mac
  • Win 32-bit
  • Win 64-bit
 Base Edition
  • Win 32-bit
Esri Edition
  • Win 32-bit
  • Win 64-bit
Esri Edition
  • Win 32-bit
  • Win 64-bit
Esri Edition
  • Win 32-bit
  • Win 64-bit
Esri Edition
  • Mac
  • Win 32-bit
  • Win 64-bit
Dependencies
  • Esri ArcGIS Desktop (32-bit Geodatabase)
  • Esri ArcGIS Server 10.1 or newer (64-bit Geodatabase)
The bit version (32-bit or 64-bit) must be the same for FME and ArcGIS.
Dataset Type
  • None (ArcSDE)
  • File (Access)
  • Folder (File-based)
Feature Type
Feature Class name
Typical File Extensions
for Personal Geodatabase: .mdb , .accdb
Automated Translation Support
Yes
User-Defined Attributes
Yes
Coordinate System Support
Yes
Generic Color Support
No
Appearance Support (Surfaces Only) Yes
Spatial Index
Always
Schema Required
Yes
Transaction Support
Yes
Geometry Type
geodb_type
Encoding Support
Yes
Geodatabase Raster Support
Band Interpretations Red8, Red16, Green8, Green16, Blue8, Blue16, Gray8, Gray16, Int8, UInt8, Int16, UInt16, Int32, UInt32, Real32, Real64
Palette Key Interpretations UInt8, UInt16
Palette Value Interpretations RGB24
Nodata Value Yes
Cell Origin (x, y) 0.5, 0.5
Rotation Support No
GCP Support No
World File Support No
TAB File Support No
Note: Esri Geodatabases can store rasters as raster datasets, raster catalogs, and raster mosaics. FME supports reading raster datasets and raster catalogs. In addition, FME supports reading mosaic datasets either as a single mosaicked raster through a raster dataset reader, or as multiple-source rasters through a raster catalog reader. Writing is supported for raster datasets but not for raster catalogs or mosaic datasets. Finally, raster support is limited to File Geodatabases and Enterprise Geodatabases.
