Removing Jobs
Removing Selected Jobs
To remove one or more jobs, select the job entries in the desired table, and click Remove (Completed) or Cancel (Queued or Running).
Note: Before jobs are removed from the Running table, the FME Engine stops processing them.
Removing All Jobs
To remove all jobs in a job table at once, click Remove All (Completed) or Cancel All (Queued or Running).
Removing Completed Jobs Older Than a Specified Time Period
On the System Cleanup page, you can create a task to run on an ongoing basis that removes jobs from the Completed table that are older than a specified time period. For more information, see Scheduled Cleanups.
