Managing Security Tokens
When you log in to the Web User Interface, FME Server grants you a security token to use the Web User Interface for a period of 30 minutes. However, FME Server automatically extends this period if you remain logged in for more than 25 minutes. To view your token ID and expiration, click the User Settings icon, and select Manage Tokens > Session Tokens.
To remove, disable, or enable a session token, select it and click Actions > Remove, Disable, or Enable.
Note: Expired session tokens cannot be enabled or disabled.
Working with API Tokens
For development purposes, you can create and manage tokens that allow unauthenticated access to FME Server.
To get started, click the User Settings icon, and select Manage Token > API Tokens.
To Create an API Token
- Click New or, to duplicate an existing token, select it and click Actions > Duplicate.
- On the Create (or Duplicating) API Token page, specify a token Name, Description (optional), Expiration, and Enabled status.
- To grant the user of the token all permissions of the current user, slide the All Permissions control to the right. Otherwise, configure the permissions as desired.
- Access: Access the Run Workspace page.
- Advanced: Access Job Directives when running workspaces.
- Access: Access the Jobs page to view the jobs you have run, or cancel any of your jobs that are currently running or in queue.
- Manage: Access and manage the jobs of all users. You can:- Cancel any job that is currently running.
- Remove the history of jobs that were previously run.
- Manage Job Queues. (Also requires Manage permission in Engines & Licensing.)
- Access: Access the Automations page.
- Create: Create workflows.
- Read: View a workflow and its log file.
- Write: Edit a workflow.
- Run: Start and stop a workflow.
- Access: Access the Schedules page.
- Create: Create schedules.
- Full Access: Edit or delete a schedule.
- Access: Access the Repositories page.
- Create: Create repositories.
- Download: Download workspaces and other repository items from FME Server into Workbench.
- Read: View repository information.
- Publish: Publish workspaces and other items to the repository from Workbench.
- Run: Run repository workspaces from FME Server.
- Remove: Remove a repository, or remove items from a repository.
- Access: Commit versions and view repository history.
- Manage: Enable version control and configure with a remote Git repository.
- Access: Access the Workspace Viewer.
- Access: Access the Server Apps page.
- Create: Create new FME Server apps.
- Read: Access an FME Server app.
- Write: Edit or Remove an FME Server app.
- Access: Access the Publications page.
- Create: Create Notification Service Publications.
- Read: View information about a publication.
- Write: Edit a publication.
- Remove: Delete a publication.
- Access: Access the Subscriptions page.
- Create: Create Notification Service Subscriptions.
- Read: View information about a subscription.
- Write: Edit a subscription.
- Remove: Delete a subscription.
- Access: Access the Topics page.
- Create: Create topics.
- Read: View information about a topic.
- Write: Edit a topic.
- Publish: Publish notifications to a topic.
- Remove: Delete a topic.
- Access: Access the Resources page.
- Create: Create connections to network resources.
- Access: Read and download a file.
- List: List the folders and files of a resource.
- Write: Write to files.
- Upload: Upload files.
- Remove: Delete files.
- Access: Access the Database Connections and Web Connections pages.
- Create: Create connections.
- Manage: Access, create, and remove connections.
- Access: Manage web services.
- Access: Access the Projects page.
- Create: Create projects.
- Read: View information about a project.
- Write: Edit a project.
- Delete: Delete a project, or delete items from a project.
- Access: Access the Dashboards page.
- Manage: Configure engines and licensing, except job queues (requires Manage permission in Jobs).
- Manage: Configure users and roles, and manage Cross-Origin Resource Sharing.
- Manage: Configure system cleanup.
- Access: Access the /metrics endpoint of the FME Server REST API.
- Manage: Configure the FME Server services.
- Full Access: Manage FME Server services.
- Manage: Configure System Events.
- Upload: Allow publishing FME packages from FME Desktop to FME Server.
- Click OK.
- Click Download to save the token. After the token downloads, click OK.
WARNING: To guarantee the security of the FME Server, ensure a token's permissions are configured so that it can be used only for its intended purpose, such as running a particular workspace.
 About permissions in FME Server
                                                 Run Workspace
Run Workspace
                                                         Jobs
Jobs
                                                         Automations
Automations
                                                        Individual Automations:
Note: Automations requires additional permissions. You are prompted to grant any additional permissions that are required.
 Schedules
Schedules
                                                        Individual Schedules:
 Repositories
Repositories
                                                        Note: Access permission is not required to run a workspace. Only Run permission on the applicable repository is required (see below).
Individual Repositories:
Note: Users must also have Allow permission on the applicable service (see Services) when running workspaces.
Note: You must uncheck all five permissions to completely remove a role from membership with a repository.
 Version Control
Version Control
                                                        Note: Version Control must be enabled to view these permissions.
 Workspace Viewer
Workspace Viewer
                                                         Server Apps
Server Apps
                                                        Individual Server Apps:
 Publications
Publications
                                                        Individual Publications:
 Subscriptions
Subscriptions
                                                        Individual Subscriptions:
 Topics
Topics
                                                        Individual Topics:
 Resources
Resources
                                                        Individual Resource connections (top-level folders):
 Connections
Connections
                                                        Individual Connections:
 Projects
Projects
                                                        Individual Projects:
Note: Access or Create permission is not required to have Read/Write/Delete permission on individual projects. These tasks can still be accomplished with the REST API.
 Dashboards
Dashboards
                                                         Engines & Licensing
Engines & Licensing
                                                         Security
Security
                                                         System Cleanup
System Cleanup
                                                         Metrics
Metrics
                                                         Services
Services
                                                        Individual Services:
 System Events
System Events
                                                         Packages
Packages
                                                        To Update an API Token's Expiration or Description
- Click on the token to open it.
- On the Editing page, update the Description and/or Expiration, and click OK.
To Remove, Enable, or Disable an API Token
Select the token and click Actions > Remove, Enable, or Disable.
Alternatively, to enable or disable a token, click on the token. On the Editing page, update the Enabled status, and click OK.
