FME Server Topic Notified
The Topic trigger sends messages generated from FME Server Notification Service Topics.
Note: Use the Topic trigger only to initiate a workflow, or a portion of a workflow. It is otherwise not necessary to explicitly define topics for a workflow to run.
- Topics: Select the topic(s) you want to send messages.
Output Keys
See Also
