Amazon S3 Bucket Modified
The Amazon S3 (Simple Storage Service) trigger polls activity on an Amazon S3 bucket, and sends JSON messages about that activity, including when files are added, changed, and deleted.
Note: When setting up an Amazon S3 trigger, you can specify how often to poll an S3 bucket. However, keep in mind that Amazon S3 is a pay-per-use service. Every poll is one request to this service.
Tip: To test that your parameters work as expected, click Validate.
  • Bucket to Watch: The bucket name in the Amazon S3 account, case sensitive.
  • Note: For more information about locating buckets in the Amazon S3 Console, see Support for Viewing Data in the Console User Guide.
  • AWS Access Key ID and AWS Secret Access Key: Provide your security credentials. For more information, see AWS Security Credentials.
  • Path to Watch (Optional): Provide a folder location in the specified bucket to watch, using forward slashes.
  • WARNING: Make sure the specified path is valid. The S3 Watch Publisher does not currently perform any verification that the path exists. If it does not, polling activity may produce false positive results.
    For example, any of the following is acceptable:
    • myfolders/testfolder
    • /myfolders/testfolder
    • //myfolders/testfolder
    • myfolders/testfolder/
    • /myfolders/testfolder/
    If left blank, the trigger watches everything in the bucket. If the path does not exist, the publisher will not start.
    Note: For more information about locating folders in the Amazon S3 Console, see Support for Folders in the Console User Guide.
  • Watch Subdirectories: To watch activity in the selected directory and all subdirectories, specify Yes. To watch activity only in the selected directory and not in its subdirectories, specify No.
  • Poll Interval: Specify how often to poll from the S3 bucket, in minutes.
  • Note: Amazon S3 is a pay-per-use service. Every poll is one request to this service.
  • Filter: By default, all actions on the specified directory are monitored, including adding (CREATE), changing (MODIFY), and deleting (DELETE) files (and folders, if applicable). To monitor only one or two of these actions, click the "x" beside the action you do not want to monitor to remove it. To add an action after removing it, click inside the dropbox and select it.
Output Keys
See Also
Key Description
file.event File action (Create/Modify/Delete)
file.path File path
s3.bucket Bucket
source Event type
