Send a Java Message System (JMS) Message
The JMS external action receives messages and relays them to Java Message System (JMS)-compliant message brokers, such as IBM WebSphere MQ.
The JMS external action has two output ports. The success port (✔) can send a message if the message broker is notified successfully. The failure port (x) can send a message if the notification fails.
Setting up a JMS Message Broker with FME Server
Before configuring a JMS external action, you must set up a JMS broker to work with FME Server. The steps depend on the broker you use, and are explained in the following section:
Sample Configurations
Output Keys
See Also
Key Description
time Event time
source Event type
error.type (Failure port only) Error type
error.message (Failure port only) Error message
See Also
