Adding Users and Roles from an Active Directory Connection
- On the Active Directory page, check the box beside the connection you want to work with. To add users, click the Import Users icon. To add roles, click the Import Groups icon.
- On the connection page, use the search bar under Browse Users to search for user(s) or group(s) you want to add. To import all users that display, check the box beside Username. Alternatively, check the individual boxes under Username. When ready to import, click Import.
- Alternatively, import a specific user under Manual Import. Specify their distinguished name (DN), and the name you want to import them as (Import As). Click Import.
- To confirm the users you added, search for them on the Users page. To confirm groups, search the Roles page.
Tip: To improve performance, use the Search bar to limit entries on the Browse page to less than 1000 users or groups.
Note: When Logging In to the Web Interface, User names, including those imported from Active Directory, are case-sensitive.
