PointOnPointOverlayer
Performs an overlay of points on points. Each point receives attributes from any point within a specified distance (tolerance), performing a spatial join. Geometry is not altered.
- Aggregating data from multiple points in the same location
- Combining attributes from different co-located point datasets
- Relating text or labels to point data
The PointOnPointOverlayer compares all point features that enter through the Point input port against each other. Each point receives attributes from all other points located within the specified tolerance distance (a spatial join). Points also receive a count of the number of matched points encountered.
Geometry is unaltered.
Aggregates/multipoint geometries can either be deaggregated before processing or rejected.
In this example, we start with a single point dataset of reported crimes, over many years. The points are routed into the Point input port of the PointOnPointOverlayer.
There are two tasks we want to accomplish.
First, we want to count how many crimes were reported at any given location within the dataset. The Overlap Count Attribute will tell us how many other points were found within 2 meters of the location (as defined in the Point Tolerance parameter, with the data in a UTM projection, ground units in meters).
Second, we will build a list attribute that contains the type of each report in the location. We enable Generate List, and add the Selected Attribute “TYPE” to a list named IncidentType.
The point are output with no changes to their geometry, but with new attributes added. The example point selected now has an _overlaps value of 8, indicating that eight points (crime reports) in total are at this location.
The IncidentType list collects the Type attribute from each of the matching points.
- Note that where Point geometries are expected as input, PointCloud geometries are not supported.
Transformer |
Can Merge Attributes |
Alters Geometry |
Counts Related Features |
Creates List |
Supported Types* |
Recommended For |
When there are multiple ways to configure a workspace to reach the same goal, it is often best to choose the transformer most specifically suited to your task. As an example, when comparing address points to building polygons, there are a few ways to approach it.
The first example, using a SpatialFilter to test whether or not points fall inside polygons, produces the correct result. But the SpatialFilter is a fairly complex transformer, able to test for multiple conditions and accept a wide range of geometry types. It isn’t optimized for the specific spatial relationship we are analyzing here.
With a SpatialFilter:
The second example uses a PointOnAreaOverlayer, followed by a Tester. The features output are the same as in the first method, but the transformer is optimized for this specific task. The difference in processing time is substantial - from 54.3 seconds in the first configuration, down to 13.7 seconds in the second one.
With a PointOnAreaOverlayer and a Tester:
Point features against which all other input points will be compared.
Point features, with attributes added according to transformer parameter configuration. Geometry is unmodified.
Features with invalid geometries will be rejected and output via this port.
INVALID_POINT_GEOMETRY_TYPE
| Group By | The default behavior is to use the entire set of features as the group. This option allows you to select attributes that define which groups to form. |
| Group By Mode |
| Overlap Count Attribute | The Overlap Count Attribute added to output point features holds the number of point features to which the point was near. |
| Point Tolerance | Each input point has the attributes from any other point within the Point Tolerance distance merged onto it. |
| Aggregate Handling |
Choose how aggregate geometries are to be handled. Deaggregate: Decompose aggregates into their individual components. Reject: Do not process aggregates and output them via the <Rejected> port. |
If attributes on the incoming and original feature share the same name, but are not geometry attributes that start with fme_, then they are deemed conflicted.
| Accumulation Mode |
Drop Incoming Attributes: Features retain their original attributes, and do not receive new attributes. Merge Incoming Attributes: The original feature will retain all of its own un-conflicted attributes, and will additionally acquire any un-conflicted attributes that the incoming feature has. This mode will handle conflicted attributes based on the Conflict Resolution parameter. Prefix Incoming Attributes: The original feature will retain all of its own attributes. In addition, the original will acquire attributes reflecting the incoming feature’s attributes, with the name prefixed with the Prefix parameter. Only Use Incoming Attributes: The original feature will have all of its attributes removed, except geometry attributes that start with fme_. Then, all of the attributes from one (arbitrary) incoming feature will be placed onto the original. |
| Conflict Resolution |
Use Original: If a conflict occurs, the original values will be maintained. Use Incoming: If a conflict occurs, the values of the incoming will be transferred onto the original. |
| Prefix | If the Accumulation Mode parameter is set to Prefix Incoming, this value will prefix attributes and measures that are being added to the original feature from the incoming feature. |
Generate List
When enabled, adds a list attribute to the Point output features, and the attributes of matching points are added to that feature’s list.
| List Name |
Enter a name for the list attribute. Note: List attributes are not accessible from the output schema in Workbench unless they are first processed using a transformer that operates on them, such as ListExploder or ListConcatenator. Alternatively, AttributeExposer can be used. |
| Add To List |
All Attributes: All attributes will be added to the output Point features. Selected Attributes: Enables the Selected Attributes parameter, where specific attributes may be chosen for inclusion. |
| Selected Attributes | Enabled when Add To List is set to Selected Attributes. Specify the attributes you wish to be included. |
| A set of control characters is available in the Text Editor. | |
| Working with User Parameters | Create your own editable parameters. |
Yes |
| Dependencies | |
| History | |
| Categories |
Search for all results about the PointOnPointOverlayer on the FME Community.
