FMEServerResourceConnector
Accesses the FME Server file storage service to upload, download, or delete files and folders or list information about files/folders from a FME Server account.
- Access data stored on FME Server file storage without using FME Server
- Manage datasets on FME Server by uploading, downloading, and deleting files and folders
- Transfer a file's contents (such as XML or raster) into or out of an attribute in FME
- Read downloaded data using the FeatureReader, or upload data written by the FeatureWriter to FME Server
- Retrieve file and folder names, paths, and other information from FME Server to use elsewhere in a workspace.
Depending on your choice of actions, it will upload or download files, folders, and attributes; list information from the service; or delete items from the service. On uploads, path attributes are added to the output features. On List actions, file/folder information is added as attributes.
In this example, the FMEServerResourceConnector is used to download an Autodesk AutoCAD DWG file from FME Server file storage. After creating a valid web connection to a FME Server account (which can be done right in the FME Server Account parameter), and browsing to the file, the Object ID is retrieved, and a destination for the download is selected.
A FeatureReader is added to read the newly downloaded dataset. Here, the ParcelLines feature type will be further processed elsewhere in the workspace.
By executing the download here in the workspace, the dataset will be refreshed every time the workspace is run.
In this example portion of a workspace, the FMEServerResourceConnector is used to download a raster orthoimage from FME Server file storage into an attribute.
The file is read from FME Server file storage, and the contents stored as a blob attribute. Then a RasterReplacer is used to interpret the blob into a usable raster format.
The combination of these two transformers avoids having to download the image to local storage and re-read it. A similar technique can be used for point cloud files, using the PointCloudReplacer transformer.
- This transformer cannot be used to directly move or copy files between different FME Server file storage locations. However, multiple FMEServerResourceConnectors can be used to accomplish these tasks.
- The FeatureReader can access FME Server file storage directly (without using the FMEServerResourceConnector), however, a local copy of the dataset will not be created.
The output of this transformer will vary depending on the FME Server Action performed.
- An Upload action will save the path of the file to an attribute.
- A Download action can save to either a folder or attribute.
- A Delete action has no output ports.
- Finally, a List action will output a new feature for each file/folder found in the path specified. Each of these new features will have attributes listing various pieces of information about the object.
Features that cause the operation to fail are output through this port. An fme_rejection_code attribute, having the value ERROR_DURING_PROCESSING, will be added, along with a more descriptive fme_rejection_message attribute which contains more specific details as to the reason for the failure.
Note: If a feature comes in to the FMEServerResourceConnector already having a value for fme_rejection_code, this value will be removed.
FME Server Action |
The type of operation to perform. Choices include:
FME Server Account |
Performing operations against a FME Server account requires the use of OAuth2 authentication using a web connection. For more information, see Using Web Connections. |
The remaining parameters available depend on the value of the FME Server Action parameter. Parameters for each FME Server Action are detailed below.
FME Server Path
Object ID |
The Object ID of a file or folder on FME Server to delete. If valid credentials have been provided as a web connection, you may browse to a location. |
FME Server Source
Object ID |
The FME Server path of the file/folder to download. If valid credentials have been provided as a web connection, you may browse to a location. |
Destination
Download as |
Select whether to store the downloaded data in a File, Folder or Attribute.
Download to Folder | Specify the path to the folder that will store the downloaded file. Valid for Download as File or Folder. |
Include Subfolders | Choose whether to download subfolders of the FME Server Source or not. Valid for Download as Folder only. |
Download to Attribute |
Specify the attribute that will store the contents of the downloaded file. Valid for Download as Attribute only. Note: FME will attempt to convert the attribute's contents to a UTF-8 string. If this fails, the attribute's contents will be created as raw binary. To ensure that the original bytes are always preserved and never converted to UTF-8, use Download as File instead. |
FME Server Path
Folder ID |
The folder ID on FME Server to list the contents of. If valid credentials have been provided as a web connection, you may browse to a location. |
Output Attributes
Default attribute names are provided, and may be overwritten.
File or Folder Name |
Specify the attribute to hold the name of an object on FME Server. |
File or Folder Path |
Specify the attribute to hold the path of an object on FME Server. |
File Size |
Specify the attribute to hold the size of a file object on FME Server. |
Last Modified |
Specify the attribute to hold the last modified date of an object on FME Server. |
File or Folder Flag |
Specify the attribute to hold the type (file or folder) of an object on FME Server. |
Relative Path |
Specify the attribute to hold the relative path to an object on FME Server. |
Source
Upload |
The source of the data to be uploaded. File: The specified file will be uploaded. Folder: The specified folder and its contents will be uploaded. Attribute: The contents of the specified attribute will be uploaded. When working with large objects, File is a better choice than Attribute as the data will be streamed directly from disk and not require that the object be stored entirely in memory on a feature. FME Server treats file uploads of the same name, in a specific folder, as duplicates, and will automatically overwrite a file if it exists in the same folder. When wanting to upload content from a folder, it is better to upload as a folder instead of setting a fixed path and sending multiple features into the connector to upload as a file. |
File to Upload |
The file to be uploaded to FME Server if Upload is set to File. |
Folder to Upload |
The folder to be uploaded to FME Server if Upload is set to Folder. |
Choose whether to upload subfolders of the Folder to Upload or not. |
Attribute to Upload as File |
The data to be uploaded, supplied from an attribute if Upload is set to Attribute. |
FME Server Destination
Folder ID | The path on FME Server to upload the source file to. You must choose a specific shared resource folder to upload your content to. |
Upload with File Name | The name of the file created from the data supplied in Attribute to Upload as File. The name must include a filename extension (for example, .txt, .jpg, .doc). |
Output Attributes
Specify the output attribute that will store the path of the file/folder that was just uploaded. |
A set of control characters is available in the Text Editor. | |
Working with User Parameters | Create your own editable parameters. |
Dependencies | FME Server account |
FME Licensing Level | FME Base Edition and above |
Aliases | |
History | Released FME 2017.0 |
Categories |
Search for all results about the FMEServerResourceConnector on the FME Community.
