Upload Service Properties File Content
                                        #                       Upload Service Servlet configuration file
                                        # This file details the installation parameters of the Upload Service Servlet.
                                        # SERVER_NAME - The computer where the Transformation Manager is running. Can be specified
                                        #               as a network name (ie: "ATHENA") or an IP. The default value is
                                        #               "localhost".
                                        SERVER_NAME={SAFE{fmeserverHostnameLocal}}
                                        # SERVER_PORT - The port on which the Transformation Manager is running on the remote
                                        #               machine. This is an integer between 1025 and 65535.
                                        #               The default value is the default Transformation Manager listening port,
                                        #               which is 7071.
                                        SERVER_PORT={SAFE{fmeserverRequestPort}}
                                        # RESOURCE_PATH - This is the path to the textual resources of the log.
                                        #                 This file stores all the messages that will appear in the
                                        #                 log as well as their code.
                                        RESOURCE_PATH={SAFE{resourcesDir}}
                                        # ENABLE_SECURITY - A boolean value that determines if security is enabled
                                        ENABLE_SECURITY={SAFE{enableSecurity}}
                                        # SECURITY_CLIENT_ID - The identifier for this client's security context
                                        SECURITY_CLIENT_ID=service_fmedataupload
                                        # DEFAULT_USER_ID - The default user account to use when authenticating anonymously
                                        DEFAULT_USER_ID=guest
                                        # DEFAULT_PASSWORD - The default password to use when authenticating anonymously
                                        DEFAULT_PASSWORD=guest
                                        # UPLOAD_DIR
                                        UPLOAD_DIR={SAFE{uploadDir}}
                                        # DEFAULT_FORMAT - The default response format (typically JSON)
                                        DEFAULT_RESPONSE_FORMAT=json
                                        # DEFAULT_ZIP_CODEPAGE - The default codepage used to interpret zip archived file names
                                        DEFAULT_ZIP_CODEPAGE={SAFE{zipCodePage}}
                                        # LOG_CONFIG_PATH - The folder path that contains the log file configuration.
                                        LOG_CONFIG_PATH={SAFE{utilitiesDir}}/config
                                        # LOG_FILE_NAME - The file name that the log files will have in common.
                                        LOG_FILE_NAME={SAFE{logPrefix}}dataupload.log
                                        #LOCALE_CONFIG_PATH - the path to the FME localization config file which contains the FME_LOCALE property
                                        #          If no file path or an invalid file path is specified, then the default system locale is used.
                                        #          If a valid file path is specified, the FME locale in the specified file is used.
                                        #          If there is no FME_LOCALE property in the file, then the default system locale is used.
                                        #          The language, country and variant are separated by underscores.
                                        #          Language is always lower case, and country is always upper case.
                                        #					 Examples: "en", "de_DE", "_GB", "en_US_WIN", "de__POSIX", "fr__MAC"
                                        LOCALE_CONFIG_PATH={SAFE{resourcesDir}}/fmeLocaleConfig.txt
                                        # CORS Shared Configuration File - File system path to the configuration file for cross-origin resource sharing that
                                        #                                  is itself shared by all FME Server services.
                                        CORS_SHARED_CONFIGURATION_FILE={SAFE{resourcesDir}}/clients/cors.properties
                                        # Charset Encoding Filter Configuration File - File system path to the configuration file for
                                        #                                              charset encoding filter.
                                        CHARSET_ENCODING_FILTER_CONFIGURATION_FILE={SAFE{resourcesDir}}/clients/charsetEncoding.properties
