SOSI GML Reader Parameters
Application Schema
SRS/Geometry Parameters
Feature Properties
Feature Properties – Attribute Handling
XML Namespace Processing
Schema Attributes
Use Search Envelope
Using the minimum and maximum x and y parameters, define a bounding box that will be used to filter the input features. Only features that intersect with the bounding box are returned.
If all four coordinates of the search envelope are specified as 0, the search envelope will be disabled.
Use Network Authentication
This parameter is always visible in some formats, and visible in other formats only when the dataset is a URL.
