You are here: Other Common Tasks > Using FME Desktop with Third-Party Applications > Reverting Applications
If the Status of an application is Extended, the Action column will contain a Revert button.
Note: Ensure that the extended application is closed.
Press the button to revert the application to a Not Extended state.
The log pane will display status information.
