Restricting Licenses to Users or Groups
You can restrict floating licenses to specific users, groups, or machines. Create a file called safe.opt
in the FlexServer directory. There is no need to reference this file in any other configuration files; FlexNet knows to look for it automatically. However, the file must be named safe.opt
, and it must be in the same folder as safe.exe
Any licenses reserved for a user are dedicated to that user. Even when that user is not actively using the license, it is unavailable to other users.
Here is an example of an options file:
RESERVE 1 professional GROUP gisdept
GROUP gisdept xxxx yyyy
This example reserves 1 FME Desktop Professional license for users xxxx and yyyy, who are in group gisdept. GROUP member names are case-sensitive.
Note: You can specify only one group. Multiple GROUP statements per license type are not supported.
To restrict a license to specific hosts (i.e. machines) instead, replace the keyword GROUP with HOST_GROUP.
For more documentation, including additional options, see <FlexServer>\Documents\LicenseAdministration.pdf, where <FlexServer> is the directory where you installed the FlexNet software.
