• Workbench Format Resources
    • FME Terminology
    • Feature Types
    • Using Database Connections
    • Feature Operations
    • Using Web Service Connections
    • FME Geometry Model
    • About FME Rasters
    • Standard FME Date and Time Format
  • All Formats
    • List of Supported Formats
  • Popular Formats
    • Quick Facts: Popular Formats
    • Bentley MicroStation Design Reader/Writer
    • Autodesk AutoCAD DWG/DXF Reader/Writer
    • CSV (Comma-Separated Value) Reader/Writer
    • Esri Shapefile Reader/Writer
    • Esri Geodatabase Reader/Writer
    • FME Feature Store Reader/Writer
    • Google KML Reader/Writer
    • MapInfo TAB (MAPINFO/MITAB) Reader/Writer
    • Microsoft Excel (XLSXR/XLSXW) Reader/Writer
    • TIFF (Tagged Image File Format) Reader/Writer
    • XML (Extensible Markup Language) Reader/Writer
  • New Formats for 2017+
    • Amazon Athena Reader
    • Apple Venue Format (AVF) Reader/Writer
    • BIM Collaboration Format (BCF) Reader/Writer
    • Cesium 3D Tiles Writer
    • glTF (GL Transmission Format) Writer
    • HTML Table Reader
    • Landsat-8 on AWS Reader
    • Landsat-8 Reader
    • MapInfo Extended TAB Reader/Writer
    • Mapzen Terrain Tiles on AWS Reader
    • Meta Raster Format (MRF) Reader/Writer
    • OGC GeoPackage Tiles Reader/Writer
    • OpenStreetMap (OSM) Protocolbuffer Binary Format (PBF) Reader
    • Pitney Bowes Multi-Resolution Raster (MRR) Reader
    • Planet Data Reader
    • SAP HANA Spatial Reader/Writer
    • Sentinel-2 on AWS Reader
    • SQLite MBTiles Reader/Writer
    • STL (Standard Triangle/Tessellation Language) Reader/Writer
    • VRT Raster (GDAL Virtual Format) Reader
  • All Files
Search the Online Transformer Gallery
    • Design File Quick Facts
    • V7 Reader Parameters
    • V8 Reader Parameters
    • V7 Writer Parameters
    • V8 Writer Parameters
    • Writing Levels in V8 (DEF Line Parameters)
    • Feature Representation
      • Attribute Linkages
        • Attribute Lists – all linkages
          • Example
        • Attribute Lists – string linkage
        • Attribute Lists – user linkage
        • User Linkages – userId of 22234 and 39030 (Extended entity data linkage)
        • Attribute Lists – dbase, odbc, oracle, ris, dmrs, informix linkages
        • Attribute Lists – framme linkage
        • Attribute Lists – incosada linkage
        • Custom Line Styles
        • XAttribute Attributes
        • Attribute Lists – XFM Linkages
        • Attribute Lists – XFM XAttributes
      • Arcs
      • Cells
      • Cells (Shared)
      • Complex Shapes Strings
      • Curves
      • BSpline Curves
      • External Reference Files
      • Multilines
      • Dimensions
      • Ellipses
      • Lines
      • Non-Geometric Collections
      • Points
      • Polygon Collections
      • Shapes
      • Solids
      • 3D Solids
      • Tags
      • Multi-text Strings
      • Text Nodes
      • Text Strings
      • XFM Feature Stores
You are here: Popular Formats > Bentley MicroStation Design Reader/Writer > Feature Representation > 3D Solids
3D Solids
igds_type: igds_3d_solid
This is supported for v8 only. This element should not be confused with igds_solid as it correspond to IGDS element type 19 (not to unnamed cell).
FME supports both reading and writing; however, support is currently limited to only extrusions. Work to add support for other solid types is currently underway.
