Installing a License File Provided by Safe Software
Follow the steps below if you have a problem with the automated license generator. If this happens, you will need to install a license file (*.fmelic
) provided by Safe Software.
For Linux users, you must log in as the same user who installed FME Desktop.
- Go to the FME Desktop License Activation web page (http://www.safe.com/activation/).
- Provide the following:
- Serial number. To get your serial number, see the confirmation e-mail you received after purchasing FME Desktop.
- Tour 10-digit registration key, which is located at the bottom left corner of the install pane of the FME Desktop Licensing Assistant:
- Click Retrieve License File and download the file.
- Navigate to FME Desktop > Utilities > FME Licensing Assistant (on Windows, this is in the Start menu). The FME Desktop Licensing Assistant opens.
- Click Install a license file provided by Safe Software.
- Browse to the location of your license file and click Activate.
- Click Finish.
Note: The number shown here is an example only.
If the previous steps are unsuccessful, you can also send an e-mail message to codes@safe.com with your serial number and registration key. You will receive an e-mail message from Safe Software with an attached .fmelic
license file.
FME Desktop is successfully licensed.
Licenses are tied to physical properties of systems. If you change your system's hardware configuration, your FME license may not work and you will need to request a new one.
