You are here: Licensing > Floating Licenses > Installing a Floating License on Linux > Locate the Flexera License Manager Files
Please read and understand the following steps before attempting to use Flexera licensing on Linux x64.
If you have purchased an FME floating or single-fixed license for Linux, copy the Linux\FlexServer directories from the FME installer, or go to Safe Software’s site and click the link Floating License Installer for Linux. This will download the file:
- fme-flexnet-linux-x64.tar.gz (Linux 64-bit)
This directory contains the lmutil and lmgrd files that you’ll need to set up a FlexNet server, and it contains the FlexNet license server software. You should install this software on your license server computer, which is the computer that will manage the licenses.
What's Next?
