SAP HANA Non-Spatial Writer Parameters
Database Connections |
Connections store authentication information. For general information about sharing database connections, please see Using Database Connections. Note that different subsets of Database Connection parameters are made available in different contexts. Connection
Select an existing connection, or Add Database Connection to define a new connection. The new connection can be made visible only to the current user, or can be shared among multiple users. |
Connection Parameters
The host name of the SAP HANA database.
The port of the SAP HANA database.
In a multiple-database environment, the name of the database to connect to.
The username and password.
Advanced
How many features will be processed in each transaction.
This parameter defines the time, in seconds, after which a query will be terminated if it has not yet returned a result.
If set to 0, there is no timeout.
