Activating a Single-Fixed License
If you have a serial number and an Internet connection, follow these steps to activate a fixed license from Safe Software.
If you already have a licensed installation, you will be prompted to update it.
If you change your system's hardware configuration after installation, your FME license may not work and you will need to request a new one.
- Open the FME Licensing Assistant
- On Windows, click the Start menu > Programs > FME Desktop > Utilities > FME Licensing Assistant.
- On Linux, log in as the same user who installed FME Desktop. Navigate to Application > FME Desktop > Utilities > FME Licensing Assistant.
- The FME Licensing Assistant opens.
- Select Activate a single-fixed license. Enter the Serial Number in the corresponding field, and click Activate.
- Click Finish.
You will see a confirmation message when FME Desktop is successfully licensed.
Troubleshooting
If you are unable to use the FME Licensing Assistant to activate a license, see Installing a License File Provided by Safe Software.
Other Licensing Options
- To connect to a floating license server, see Installing a Floating License Server on Microsoft Windows.
- To activate a trial version of FME, visit: http://www.safe.com/evaluation/index.php
