Syntax FACTORY_DEF VectorOnRasterOverlayFactory [FACTORY_NAME ] [INPUT (RASTER|VECTOR) FEATURE_TYPE [ ]* []*]* ACTION [INTERPOLATION_TYPE (nearestneighbor|bilinear|bicubic|average4|average16)] [GROUP_BY []+]* [OUTPUT POINT FEATURE_TYPE [ ]* []*]* Overview Note: This factory is not supported by FME Base Edition. This factory was designed to be used in situations where processing is done with a single raster and many vectors. The processing pattern is defined as follows: for each group, incoming valid vector features are stored until a reference raster is received for this group. Immediately following the reception of this raster, any stored vectors are processed using the raster. The vectors that come after reception of the raster are processed as they are received. Multiple rasters entering the factory in the same group will generate an error. The processing that will take place depends on the value specified for the ACTION parameter. However, every scenario will involve outputting one vector feature for every vector feature that the factory receives. A single different raster may be used for every individual group of incoming features. The GROUP_BY parameter should be used for the purpose of defining such feature groups. Currently, the factory supports only the following ACTION: RETRIEVE_BAND_AND_PALETTE_VALUES In this mode, the factory requires points as input vectors. For each input point, a point is output which contains the attributes from the input point and reference raster, as well as the band and palette value(s) at the location of the point. An instance of the following list attributes will be created for each band/palette on the raster: _band{}.value _band{}.palette{}.value When used in this mode, the The INTERPOLATION_TYPE parameter specifies the interpolation method to be used when retrieving raster values from points. Nearest Neighbor interpolation is the fastest and least accurate, while Bilinear and Bicubic are slower but will weight surrounding data values into the final result. Average 4 and Average 16 have a performance similar to Bilinear and are useful for numeric rasters such as DEMs. Output Tags POINT The vector created for each input vector feature will be output via the port associated with this tag. Note: The output features will contain any attributes that the corresponding input vector features had, as well as attributes contained on the reference input raster.
