Syntax FACTORY_DEF SolidIntersectionFactory [FACTORY_NAME ] [INPUT CLIPPER FEATURE_TYPE [ ]* []*]+ [INPUT CLIPPEE FEATURE_TYPE [ ]* []*]+ [MULTICLIP (YES|NO|CLIPPERS_FIRST)] [CLIPPER_ATTR_PREFIX ] [CLIPPEE_ON_BOUNDARY (INSIDE|OUTSIDE|BOTH)] [MERGE_CLIPPER_ATTRIBUTES [(YES|NO)]] [OUTPUT_NO_CLIPPERS_AS_OUTSIDE] [OUTSIDE_NO_CLIPPERS_ATTR ] [DO_NOT_AGGREGATE [(YES|NO)]] [GROUP_BY []+] [OUTPUT (CLIPPED_INSIDE|CLIPPED_OUTSIDE| INSIDE|OUTSIDE|UNUSED|REJECTED) FEATURE_TYPE [ ]* []*]* Overview This factory is used to perform a geometric clipping operation on input features. It takes two types of features identified by the CLIPPER and CLIPPEE input tags. Clipping features are identified by the tag CLIPPER. These features identify the area against which all CLIPPEE features are processed. The CLIPPER can be a solid or multi-solid feature. Any non-solid clipping features that are encountered are destroyed and a warning is output. The "clippee" features are identified by the tag CLIPPEE. These are clipped in such a way that features totally within the CLIPPER feature are output from the factory via the INSIDE tagged output clause. Valid clippee features for the SolidIntersectionFactory are points, solids, point clouds, and aggregates of these geometries. Any invalid features will be output out the REJECTED port. The clipping operates in one of three ways according to the style of multiclipping selected by the tag MULTICLIP. If the default option of NO is selected, only one input clipper will be accepted. For each instance of the factory, the first solid feature that matches the CLIPPER specification is used as the clipping solid, and other solid features are destroyed and ignored. Tip: Since CLIPPEE features must be held by the factory until the CLIPPER feature arrives, take care wherever possible to ensure that the CLIPPER feature arrives before any CLIPPEE features. If the YES option for the MULTICLIP tag is selected, multiple CLIPPER features may be given to the clipping factory. The CLIPPERs will be applied to all the CLIPPEEs in the order that they are input. In this mode, all the CLIPPEE features are held in a cache until all the CLIPPERs and CLIPPEEs have arrived into the clipping factory. Then, when we are sure that all clippers have arrived, clipping begins. The CLIPPERS_FIRST option for the MULTICLIP tag is the third and final mode which is a modification of the YES option that allows for better efficiency. If selected, the clipping factory will expect the first feature input to be CLIPPERs. Once the first CLIPPEE feature is given, all subsequent CLIPPER features will be output immediately by the REJECTED tagged output clause. In this mode, no CLIPPEE features are held, and clipping begins when the first CLIPPEE arrives. CLIPPEE features that intersect the CLIPPER features are broken up into pieces, with those pieces on the inside of the CLIPPER features being output by the CLIPPED_INSIDE tags. Those portions outside the clipping solid are output via the CLIPPED_OUTSIDE tagged output clauses. If a CLIPPEE feature is found to be inside a CLIPPER, or is clipped inside a CLIPPER, the inside parts are no longer clipped by other CLIPPERs. As such, results may vary depending on the order that the CLIPPERs are given to the clipping factory. Features completely outside all of the CLIPPER features are output by the OUTSIDE tagged output clause. Features that are clipped outside of a CLIPPER will have their outside parts clipped by any subsequent CLIPPERs. If MERGE_CLIPPER_ATTRIBUTES is specified, then whenever a clippee is found to be inside or clipped inside a CLIPPER, the attributes of the clipper will be copied to the inside parts of the output features. The CLIPPER_ATTR_PREFIX directive specifies a string prefix to be added to the attributes of a CLIPPER that are copied to a CLIPPEE. If attributes of the same name already exist on the CLIPPEE, they will be overridden. If this prefix is not specified or is empty, the attributes will still be copied to the output features, but they will not overwrite any existing attributes of the same name. The CLIPPEE_ON_BOUNDARY directive directs what action should be taken with clippee features that lie entirely on the boundary of the clipper. If the value INSIDE is given, then these features that lie on the boundary are output via the INSIDE tagged output clause. If the value OUTSIDE is given, then these features that lie on the boundary are output via the OUTSIDE tagged output clause. If BOTH is given, points on the boundary are duplicated and output as both INSIDE and OUTSIDE. If the CLIPPEE_ON_BOUNDARY directive is not specified, the default behavior is INSIDE. All of the output tags are optional. If the GROUP_BY clause is given, then each CLIPPEE will only be clipped by CLIPPERs that contain the same values as itself in the attributes specified by this clause. TO BE RESOLVED OUTPUT_NO_CLIPPERS_AS_OUTSIDE, OUTSIDE_NO_CLIPPERS_ATTR clauses added to Syntax section above, but not documented.
